I am sure you already know this, but the first thing to do is find and repair the leak. I have done three conversions by replacing only the drier and orifice tube with good results. After replacing them add the appropriate amount of the proper oil, have your system vacuumed out, and charge with about 85% of the amount of R12 it called for.
If you replace the dryer (actually the accumulator) and the orifice there's not much left. Flush the old oil out of the accumulator and condenser, drain the compressor, add the proper amount of Ester oil, evacuate and recharge. Of course reseal all of the connections.
Actually, with the recent increases in the price of R-134A and the price of R-12 coming down, it can be better to stick with R-12 if you know the system is tight.
I've seen a lot of weak fan clutches on early 90s Fords. They will pull enough air to keep the radiator cool but not enough for the AC to cool properly at low speeds. They will usually pass the "feel" test. Keep this in mind.
One real problem area here in Northern Ohio is the tube coming from the bottom of the condenser. Around here they all seem to rust through.Also, Watch for compressor shaft seal leaks, they can come back to bite you.
ok thanks guys....Yea finding that leak may be hard. I'm sure it's a seal...
This truck belonged to an old man, that was a family friend and he passed .
I recived the truck and it has 40,000 miles and it's in GREAT shape.
But last week I tore down an old bulding and hauled it off.
I'm thinking that whit the extra stress on the truck it made a seal leak badly
because the ac was allready weak...
When I did the conversion on the 88 someone told me to replace the fan clutch so I did and thought I wasted 40.00 but come to find out I did a good thing because like you said it passed the feel test....
Thanks again guys I will do the job this weekend and ley yall know how it goes.
Instead of trying to find one leaking seal, just do them all. It's about $10 or less to reseal all of the spring locks and the compressor manifold. As long as the condenser is ok you should be good to go for another few years.
The only caveat is the compressor shaft seal. You could pull the compressor and have the seal replaced for insurance, if you are inclined. Shaft seal leaks are hard to detect without a really good ($$$) sniffer.
