Electrical troubles
Old Apr 17, 2006 | 07:50 AM
Fullcrew7.3's Avatar
Fullcrew7.3
Unhappy Electrical troubles
I've got a '96 F350 and I've started having electrical problems lately. Fuse blew and took out my speedo and overhead lights. Changed fuse and overhead lights stayed on even with the key off. Also, fuse would blow after a couple miles of driving. Ended up taking the bulbs out of the cab lights and now it's OK. Anything you'd suggest looking at first. Headlight switch maybe? I pulled each of the door switches indiviually to see if any on was shorting, but that didn't change anything. Kinda stuck. Thanks
Old Apr 17, 2006 | 08:00 AM
j&bsuv's Avatar
j&bsuv
you might try the headlight switch. My bronco needs a new one you have to move it just right to make the head lights and the tail lights come on at the same time. I would start there. then again I have such bad luck with electrical stuff you might be better off to ignore this message
Jeff
