1978 - 1996 Big Bronco
95 351 sputters on cold start
Old Apr 17, 2006 | 06:56 AM
Alta's Avatar
Alta
My guess is this is problably some cold start valve or sensor, but when cold the thing cranks a little longer than it used to and then sputters a bit before it idles normally. Im hoping this is some simple fix and maybe its related to my 10 mpg gas milage. Ideas?
Old Apr 17, 2006 | 11:54 AM
Streetgang's Avatar
Streetgang
I would start off by checking for fault codes.....and, no the check engine light does not have to be on for codes to be stored.
If I had to take a guess though....I would look at the IAC and also all the usual ignition tune up stuff.......when was the last time it had a tune up?
cajunron
May 10, 2016 03:53 PM
70FE250
Mar 21, 2016 10:38 AM
70FE250
Feb 11, 2016 05:50 PM
Jbru167
Apr 6, 2009 03:28 PM
jleberer
Feb 2, 2007 02:49 PM
