front brake problem
Old Sep 10, 2002 | 08:46 PM
big block power's Avatar
big block power
front brake problem
I got fixing manuals but no diagnosis manuals or knoledge of
brakes, I have a sticking wheel cylinder,little kicker in the seat sometimes but that ended, now the front pulls and provides no
brake action the back brakes work like brand new basically.
the truck is a 72 ranger camper special,power brakes or power
assist,something power. thanks for help!
1970 250 camper special, 390 2v.4gear,w/4.10 rear
manual everything.
1972 250 ranger xlt camper special,390 holley 4v, 9.6to 1 comp.
4 gear, 3.54 rear, huge improvement!
Fe power
Old Sep 11, 2002 | 12:19 AM
krazdndenver's Avatar
krazdndenver
front brake problem
Are these drum or disk?
Old Sep 12, 2002 | 09:00 PM
1 Big Mike's Avatar
1 Big Mike
front brake problem
Old Sep 12, 2002 | 09:54 PM
big block power
front brake problem
drums, all round,
Fe power
Old Sep 13, 2002 | 01:46 AM
Scotty1's Avatar
Scotty1
front brake problem
Sounds like the front drums need to be adjusted. Start with the side the a re pulling to. IE if it pulls left do the left first. There is a STAR aduster just behind a slot on the back of the brake cover. a insert a screw driver and turn which ever way they get easier to turn. They will turn opposite directions. You want them loose enough to just barely hear them drag. Not enough to add much resistance. Ajdust those and see what that gets you.
Scotty
Old Sep 13, 2002 | 08:28 PM
Mike W's Avatar
Mike W
front brake problem
I would replace the wheel cylinders, they are cheap. Also, put in new springs and the other misc hardware. I would replace the adjuster if the teeth look worn.
Camper Special Gene
19
Mar 23, 2013 12:01 AM
Camper69Special
Nov 5, 2011 11:13 AM
muddymatt
Aug 27, 2010 05:49 AM
Purely Ford
Jan 20, 2003 02:38 PM
froby
Jan 4, 2002 08:52 PM
