Removing window cranks????
Old Apr 16, 2006 | 09:44 PM
99RangerE's Avatar
99RangerE
I'd like to remove the window cranks on my 99 ranger to replace the factory speakers.....how can i do this without purchasing a tool???????
Thanks
EThan
Old Apr 16, 2006 | 09:47 PM
RangerRaider's Avatar
RangerRaider
They are almost like a cover type deal.. If you pull on the base of it the cover will pop off and you need a torx screw driver to take it off.. Fairly simple compared to a GM vehicle.
Old Apr 16, 2006 | 09:48 PM
RangerPilot's Avatar
RangerPilot
The cover should pop off (just grab around the edge of the handle toward the center circular part and pull). Move it off to one side, and stick a Torx screwdriver down in there. Not sure on size, sorry. Unscrew it and the thing pops right off.
RP
Zach
Old Apr 16, 2006 | 09:57 PM
99RangerE's Avatar
99RangerE
ok , so more towards the door panel i can just tug hard , it'll pop off , then uunscrew w/torx wrench? OK thanks i'll give it a go......awesome response time....I expected to wait! thanks again
Old Apr 16, 2006 | 10:01 PM
RangerPilot
Yep just pop the little cover off, unscrew the Torx, pull the handle off (you may want to re-orient it when you put it back on so it doesn't rattle as bad if you crank the music as it sits in front of the speaker in some positions).
Your truck may be slightly different, but on mine (no power windows, locks, mirrors, etc.), I just had to pull the handle, lock the door, unscrew a screw on the top front of the door and the bottom rear, and then give a good firm shove up, and it popped right off.
RP
Zach
Old Apr 17, 2006 | 08:13 PM
blueranger99's Avatar
blueranger99
I think you need a t-15 torx screwdriver. I've had mine off a couple of times messing around with the door light switch.
Old Apr 19, 2006 | 12:04 AM
Peter94's Avatar
Peter94
lol, i think i've had all the door panels off all of the vehicles i've owned/driven at one time or another. But yeah, ditto on the torx. It actually might be benificial to get a nice set of torx bits as there are some every here and there on these trucks, like on the MAF, those are security bits though, with a little stud in the top of them.
Old Apr 19, 2006 | 08:17 AM
fordboy_52's Avatar
fordboy_52
i took a dremel to mine and made them straigh screw driver bolts, lol
