key switch?
Old Mar 15, 2002 | 01:19 AM
thewall's Avatar
thewall
key switch?
Old Sep 15, 2002 | 10:27 PM
crash71us's Avatar
crash71us
key switch?
i have a electic draw problem.can anyone tell me the postions on my key switch?acc.,start,run ? should the switch be left in the straight up position for park? what is the difference between a 352 and a 360?what parts can be swapped? my vin says 360 but block says 352 why?thanks fopr any help
Old Sep 15, 2002 | 11:30 PM
Scotty1's Avatar
Scotty1
key switch?
Unless you have cross referenced the casting code for your motor then you probably do have a 360. Almost every FE powered engine has a 352 cast into the front of the block. The casting code is located below the oil filter get that and we can tell you what you have. The only other # i know of on the front of the block is a mirror image 105.
The positions on my switch if I remeber are straight up = off. left = acc. right = run. farther right = start. I could be wrong but i pretty sure that is how it goes.
Hope this helps you
Scotty
