1966 - 1977 Early Broncos
Source for power steering boxes?
Old Apr 16, 2006 | 01:36 AM
go_racing84's Avatar
go_racing84
I figured I'd ask this in the EB forum, maybe I'd have some luck.
Does anyone here have a good source for early Bronco power steering boxes that don't cost upward of $300? I realize they're a pretty desirable design for a lot of different applications, but jeez, people treat them like they're solid gold. I've explored the idea of an IFS Toyota box, and they are quite a bit cheaper, but I like the Bronco box for its direct compatibility, and the fact that I'd be able to use my drop pitman arm on it.
Anybody know something I don't? Secret supply of them somewhere?
(And if anyone has one laying around that needs to be taken away... lemme know...)
Old Apr 16, 2006 | 10:03 PM
okst1's Avatar
okst1
Good luck. I paid $700 for a rebuilt one.
Old Apr 28, 2006 | 12:59 AM
fishmanndotcom's Avatar
fishmanndotcom
i used a gearbox from a 77 F150. it fits very nicely and is almost a direct swap! just have to drill 2 new holes. and i got mine for $10 from a j-yard! hard to beat that!
-cutts-
Old Apr 28, 2006 | 01:08 AM
ford390gashog's Avatar
ford390gashog
find one from a 73-79 truck. its a direct swap and you drill two extra holes.
Old Apr 28, 2006 | 01:10 AM
ford390gashog
Lares makes them Part#805 www.kragen.com but also check www.rockauto.com
Old May 1, 2006 | 12:28 AM
Boba Fett's Avatar
Boba Fett
You need to go to a u pull it junkyark with a pickle fork and be on the hunt for a 73-79 Ford F-150 4x4 or 78-79 Bronco power steering box. That mounts right where your stock box does and BC Broncos sells a frame re-inforcement too.
If you use a 4x2 box same years you need another 4x2 box from 80s to make it work.
Its on the BC Broncos website in Tech.
Old May 1, 2006 | 03:16 PM
bmc69's Avatar
bmc69
Uh, not quite....you need the 'guts' from the 4x2 box to install in any of those 4x4 boxes you mentioned...to make the rotation correct for the EB. You also have to play around with the mounting holes since only one of the F-150 4x4 box holes matches up with the stock EB fame holes. I drilled and reinforced one new hole in the frame and 'added' one new hole to the steering box so I could use another of the stock frame holes. Been there, done that...
I'm running the 2wd F-150 box on my '69, mounted on the inside of the frame with the Wild Horses bracket and cross-support kits. Works great with the 5.5" lift but would not be a good choice for a truck with less than 3.5" lift IMHO.
Old May 1, 2006 | 10:02 PM
Boba Fett's Avatar
Boba Fett
Think about this..... the 4x4 and Bronco box does not need its guts changed becuase it mounts outside the frame in front of the axle, just like the EB, in the same area as the EB..... The 4x2 Box, on the other hand mountsbehind the axle, which is why it needs its guts changed.... The pitman are of the 4x2 box is pointing forward, whereas on the 4x4 box rearward. It has to work unless what you are trying to say is that on the Bronco you turn the steering wheel opposite the direction you turn it on an F150
Old May 1, 2006 | 10:25 PM
go_racing84
Wait... those that are saying the '73-79 F-150 or '78-79 Bronco is a direct swap... don't those boxes steer reverse of the early Bronco / early F-100? That is to say, on my truck, the pitman arm points toward the rear of the truck, and I understand that the '73-79 boxes point toward the front.
Old May 1, 2006 | 10:42 PM
Boba Fett's Avatar
Boba Fett
Its only a direct swap if you use a 73-97 F150/F250 4x4 or a 78-79 Bronco steering box. You should alse re-inforce the frame rail which you can do with a kit from BC Broncos because the box was intended for the heavier truck frame. You can also get picture to help you out from their website's tech page last time I checked.
If you use a F150 4x2 box you can either mount it inside the frame rail and flip the pitman arm and you need a special bracket and drill holes.... or if you want to mount it outside the frame rail like the manufacturer did you need to get the worm gear from early 80s 4x2 Ford F-150-250 (81-89? I think) which fits inside the 73-79 box and is set up for outside the frame rail box in front of the axle.
Old May 1, 2006 | 10:51 PM
go_racing84
So it is a direct swap. Wow. I've been going off of this tech article and what an ebay seller told me, and they both say that those boxes steer the wrong direction for the F-100.
Tech Article
Old May 1, 2006 | 10:59 PM
Boba Fett's Avatar
Boba Fett
Take the box when it's in you hand and turn the sector shaft end that the steering connects too, the pitman arm will spin just like your EB's if it is a 4x4 box.
Old May 2, 2006 | 11:16 AM
bmc69's Avatar
bmc69
I'm not 'thinking about it' ..I'm LOOKING at it; both flavors of steering setups are on some of the 7 EBs in my yard right now and I put them in there. The ONLY way you could possibly use the F150 4x4 box without changing its rotation direction, by swapping the internals from a 2wd box, is if you leave the pitman arm facing forward...which leaves the end where the drag link attaches sticking practically out the front of the truck and results in a really bad angle betwen drag link and tie rod. And believe it or not ...I think I actually have a pic of one that was done like that. It's ugly..but it sorta worked.
And like I said before, the only direct bolt-up is the EB box..all other options require new holes and/or brackets to fit them on the frame.
Old May 2, 2006 | 11:27 AM
bmc69's Avatar
bmc69
Behind the axle..on an EB?? 25 years of building EBs and I've nver seen anyone attempt that. The 4x2 box is mounted in the same location as the stock EB box, but on the opposite side of the frame. Pic here of exact setup I'm using on one of my rigs
Old May 2, 2006 | 01:31 PM
bmc69's Avatar
bmc69
Copied from Chuck's web site (BC Broncos) tech tips library
POWER STEERING CONVERSION
<TABLE cellSpacing=0 width=154 align=right border=1><TBODY><TR><TD></TD></TR><TR><TD>4X4 F-150 power steering box.</TD></TR></TBODY></TABLE>The 1979 F-150 4X4 power steering box (at right) is about the same length as the Early Bronco power steering box. The EB pitman arm will fit. The F-150 box bolts to the outside of the frame. The bore is a litle larger than the EB box. Two of the three mounting holes will need to be moved to match the EB frame holes. The worm gear/rack will need to be replaced with the worm gear/rack from a 4X2 power steering box like the one below to make the 4X4 box steer correctly for the EB.
