clutch sizes?
Old Apr 15, 2006 | 09:51 PM
montster's Avatar
montster
clutch sizes?
hey I just swaped a 81 300 into my 83 300 bronco when I did I noticed the clutch on the 81 was like new but the teeth on the flywheel had a run in them so I pulled the flywheel off the 83 thats when I saw that the clutch on the 83 was smaller(diameter) the flywheel had holes for either clutch? measured and the larger still fit and everything bolted up and clutch feels ok are the release bearing the same? I didnt have the origional one from the 81 I havent finished the rest of the little thing so I havent been able to test it, I am assumeing bigger is better?
Old Apr 16, 2006 | 09:36 AM
Ranger GT2's Avatar
Ranger GT2
Either clutch will work. The flywheel will accept either a 10.5 or 11 " clutch. Yes the 11 " clutch is a little more heavy duty. The throw out bearing should work on it also. Do remember that you can only use a 300 flywheel on a 300 six motor. You cannot use a small v 8 flywheel due to being balanced differently.
mtfleming11
Nov 25, 2012 01:00 PM
jas88
24
Mar 14, 2011 11:29 AM
Boss300
Oct 31, 2009 01:31 PM
northernmoose
Jul 19, 2007 07:47 PM
motorhead_83
Jul 19, 2004 07:40 PM
