Sponsored by: Real Truck
Lower door weatherstrip
Old Apr 15, 2006 | 09:40 PM
Ricohman's Avatar
Ricohman
I have a 99 V10 ext cab and I have noticed (besides the lower door seam rust) that my truck never came with the lower weather stripping. All the holes are there for the mounting pins but the weatherstrip is absent on all four doors.
The dealer wants about $250 for the 4 pieces.
Is there a cheaper aftermarket alternative?
Would the weatherstrip help prevent more rust?
Thanks.
Old Apr 16, 2006 | 09:39 AM
Big D's Avatar
Big D
You should be able to get them here for less than $100 bucks for all 4. IMy 99 needed a drivers side (front) lower and it was about $20 bucks.
http://www.parts.com/partlocator/ind...?siteid=213787
Old Apr 16, 2006 | 10:05 AM
Studenut65's Avatar
Studenut65
I replaced my weatherstrip down at the bottom of the door. After about a half a year of leaving it on, I finally took it back off. I found that it held moister right along that seem and created more rust. I ended up grinding down the rust, POR-15ing it, painted it, and used a sealer to seal the seam up before putting another layer of paint on it. I figure that I'd let the seals off of the door and allow the air in there to dry out those seems when they get wet. Just my 2 cents.
Nate
Old Apr 16, 2006 | 11:49 PM
jake00's Avatar
jake00
Thanks.
WoW my dealer wanted 20 bucks for 1 piece
