ARP studs/Hypermax gaskets
Old Apr 15, 2006 | 09:28 PM
SoCalSuperDuty03's Avatar
SoCalSuperDuty03
Hey People,
My truck is at the dealer for the headgasket/stud job, EGR cooler, and possibly a turbo. I feel really comfortable with my friend the diesel tech pulling the cab off.... if he wasn't my longtime friend/dragracing buddy I would be paranoid. Also, all the FoMoCo and IH training he has under his belt (starting with the 6.9's) makes me feel better too. I am using the Hypermax '500' gaskets (c-rings w/o machine work) and ARP studs. After I get it back together I am going to Dyno thrash it and put it to the tow test with all the goodies plugged in, and I will report back. I also have an extra set of ARP studs in the box if anyone needs them, I don't know if they are on backorder everywhere still.
Tim
Old Apr 17, 2006 | 08:08 PM
04 LARIAT STROKER's Avatar
04 LARIAT STROKER
let me know what you think when you get it done...i am thinking about doing it also...when you get it back you should drive it easy for a while and then retorque the heads to be safe
Old Apr 17, 2006 | 09:41 PM
Industrial_dude's Avatar
Industrial_dude
whats up Tim,
If I didnt just have to replace my tranny again for the 3rd time id do the same setup as you. Its so tempting but till when do you tell yourself your spending to much on your truck ?? it goes on forever. Good luck let us know how it runs (hauls azz)
Old Apr 18, 2006 | 12:02 AM
SoCalSuperDuty03
Hey George,
What's up Bro? Sorry to hear about the crappy trans. luck. I will let you know what happens, looks like I may be getting a new turbo, and I am installing a Fluidamper while it is apart. There is also a TSB for the serpentine belt idler/tensioner, sounds like a great time to take advantage of it! Who did your trans. this time?
Tim
Old Apr 18, 2006 | 12:11 AM
SoCalSuperDuty03
And you are absolutely right about our trucks.... the should have coin and bill slots built in the door handles!!
Old Apr 19, 2006 | 02:24 AM
Industrial_dude
hey Tim,
this time I actually took the truck to a dealership (star ford in glendale) for a bad injector, and while they were at it I had them do my brakes, fix my 4wd, and change the fluids. While they flushed the tranny they told me there was metal shavings and I should get a new one, turns out I blew a planetary gear. I then ordered a whole transmission from suncoast and had them install it. I didnt even know I had a bad tranny. I could only imagine how many more trannys ill have to go thru with that extra power I could push with the hypermax gasket and head studs lol. If you dont mind me asking how much are you going to end up spending on this project? and what program are you going to use? are you considering larger injectors and a different fuel pump?
Old Apr 19, 2006 | 07:57 AM
gofast66's Avatar
gofast66
ARP studs/Hypermax Gaskets
Hi. Just wanted to know more about thes Hypermax gaskets.IE, who Makes them? where to get them, are they better than Fords or anybody's gaskets for that matter? am in the some boat with no warrenty left. Thanks for any help. Dan.
Old Apr 26, 2006 | 02:20 AM
Industrial_dude
SO TIM! whats up?
I saw in another thread that you got em done.... have you ran a more aggresive tune yet?? you got a curious george over here hehe ???
Old May 1, 2006 | 12:16 AM
SoCalSuperDuty03
Hey George!!!
I have about 1000 miles on it since the cab went back on... and I am digging it! No more coolant all over EVERYTHING, shocks, engine, AMP steps, etc. I have had both the SCT Excal tunes by themselves, and stacked with the Edge Juice on 3,4,5 settings, all which produced massive coolant loss before. While I was in there I got a new Turbo (warranty), and installed a Fluidamper. I also 'optimized' the EGR. The studs got torqued to 235 lbs. I will let you know more when I get some more miles on it.
have a great day bud!!
Tim
Old May 1, 2006 | 12:18 AM
SoCalSuperDuty03
Hey Dan, Hypermaxengineering.com, the gaskets are really good quality, fit perfectly, and I am hoping have some serious longevity
Tim
Old May 2, 2006 | 09:40 PM
actionjackson's Avatar
actionjackson
just curious how much that is costing you ? Or they doing it under warranty ?
Old May 2, 2006 | 10:14 PM
NavyPowerstroker's Avatar
NavyPowerstroker
Hey Tim I think you meant www.gohypermax.com right? Which ones did you get? I see two sets..
Old May 2, 2006 | 10:34 PM
gofast66's Avatar
gofast66
Thanks socalsuperduty keep us informed on how they are holding, need to do mine soon and am not looking forward to it.
Old May 3, 2006 | 02:10 AM
Banshee Ben's Avatar
Banshee Ben
Will the dealer, when faced with a blown gasket, put in a better gasket and studs like you did, or will they replace the bad design with another bad design.?
Old May 11, 2006 | 12:51 AM
SoCalSuperDuty03
Hey people I just checked in for a minute, gotta go drive a train right now.... I will put up some answers tomorrow. Everybody have a great day/night!!
Tim
p.s. I am soooooo in love with this truck again it isn't even funny!!!!!
