Sponsored by: Real Truck
running rough at idle
Old Apr 15, 2006 | 11:04 AM
99f250's Avatar
99f250
Red face running rough at idle
.so i changed the fuel filter. when i started it back up, ran really rough so i figured i got some air in the lines. purged that out and still running rough. had an extra crank sensor so threw that in-- still no change.checked codes and got p-0603, the usual for a installed tuner. it also surges when it kicks into overdrive likes its running out of gas. anyone have any ideas?
Old Apr 15, 2006 | 11:22 AM
whomrig's Avatar
whomrig
Check to see if a vacuum hose was unplugged by accident. also some dirt may have gotten in the lines and is clogging an injector.
Old Apr 15, 2006 | 11:24 AM
99f250's Avatar
99f250
if it is an injector, is there anyway to clean?
Old Apr 15, 2006 | 11:35 AM
whomrig's Avatar
whomrig
the only way i know to clean injectors, is to run a good injector cleaner thru the system.
