How do I...steering column
1. Where the shifting lever connects to the steering column is loose. I don't see a way to make it fit better so there is less play in the shifting lever. Anyone know how to fix this (no, it isn't the screws toward the lower part of the steering column, I know about those
)2. When I remove the bkack, plastic cover around the steering column and the ignition, how do I get the lower black part around the adjusting lever for the tilt of the steering wheel? Was afraid if I twisted too hard it would snap.
Thanks in advance.
