Help!!
Old Apr 14, 2006 | 02:33 PM
Maxxizbak's Avatar
Maxxizbak
Help!!
Hi, I am not the biggest on working on vehicles, I kow a lil...but I am lost...my truck 1968 F100...ran great one day...and the next started backfiring...I replced plugs, wires, cap rotor...and now...it is cranking to slow to start and the relay starts smoking it gets so hot...any ideas on how i can fix this?
Old Apr 14, 2006 | 03:14 PM
bertha66's Avatar
bertha66
Sounds like the timing has sliped or the timing chain has jumped. Roll the engine up onto top dead center and pull the dist. cap and see where the rotor is pointing.
Old Apr 14, 2006 | 03:17 PM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome Max to Ford Truck Enthusiasts!
We are happy you have chosen the best source for Fords.
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old Apr 14, 2006 | 03:20 PM
jor's Avatar
jor
You may have screwed up the firing order. If your motor is an FE, the firing order is 1-5-4-2-6-3-7-8. The cylinders on the right side (passenger) are numbers one through four, front to back and five through eight on the left side. For starters, identify the wire that runs from #1 to the distributor. Then start tracing your other wires. Moving in a counter-clockwise direction on the distributor cap, your wires should follow the above order.
jor
