oil filter?
Old Apr 14, 2006 | 02:07 PM
pointeca's Avatar
pointeca
oil filter?
Today me and a buddy changed the oil pan on my 94 idi turbo, I pulled the old pan off, then came in for lunch, I went back out and my buddy had taken off the old oil filter, he wasn't sure but he thought that a little spring popped out, from somewhere in between the filter and filter housing. Is this possible, is there a spring somewhere in between the filter? Or is this just a spring that fell from somewhere else on the truck?
Old Apr 15, 2006 | 12:53 AM
PLC7.3's Avatar
PLC7.3
Look on the rear header there should be a hole with a washer staked into it, the washer should hold a fibre disc with a spring spring behind it.
Old Apr 15, 2006 | 05:15 PM
pointeca's Avatar
pointeca
ok, thanks plc7.3, I'll check that out.
