98 Contour V6 Rattle
Ahh crud! I was so busy being a smart-alik I forgot to ask about the rattle, luckily you answered. I would take a length of vacuum hose, stick one end in your ear and use the other to try and pinpoint exactly where the noise is coming from. Sounds in the engine compartment with the engine running often get bounced around making them sound like they're coming from somewhere they're not. It makes it easier to narrow down the posibilities. I once spent a month trying to figure out a rattle in the rear of an engine only to find out it was a loose bolt in the front that holds the oil dipstick tube to the engine.
How bad is the job? I replaced them a few years ago on an 87 Topaz without removing the engine which would have been a real pain. I just shuffled the engine sideways a bit and tilted it. This rattle sounds eerily similar. It looks like there is more space on that side of the engine on the Contour but it looks like the valve covers and more junk has to come off also.
The rattle on the Topaz progressed from an occasional click to a continuous rattle over a long period. The Contour rattle started suddenly, one day no rattle, the next day a big one.
The Contour also has a big warm weather oil leak on the opposite end of the engine to fix also. It seeps a little in the wintertime. In the summer it can use a quart of oil weekly.
-I hate Contours...
-I hate Contours...
I am good at the intake R&R. I can do that and replace the fuel pressure regulator in 30 minutes flat with homeowner tools which is a far cry from the 3 hours the local Ford dealer said was flat rate...
Will the rattle get worse or will the engine self destruct soon if we just let it rattle for a while? My son just got a new job and may be able to afford another vehicle in a few months if this one will last a little longer.
It is probably nibbling at the guide already and throwing pieces. It seems to be a common problem with ALL the new engines using plastic parts inside engines. By new I mean anything since about ~80. It is a shame, but I can understand why from an engineering viewpoint but at the same time I can see reasons for not using them also. It is one of those tradeoffs that often does not come out to well. This particular engine does not even have 50K miles on it.
