Tank Selector Valve
Old Apr 13, 2006 | 06:23 PM
marcford's Avatar
marcford
Tank Selector Valve
I recently installed a Pollak 6-port selector valve in my 1985 E-350, 460 V-8 Dual tanks. The original wiring colors at the old valve connector don't match any Manual I can find and the wiring colors on the new valve don't match anything. Also the front tank pump runs without the tank selector valve hooked up. Anyway if I get some advice on how to wire this valve I would be very gratefull.
Old Apr 14, 2006 | 10:20 AM
kawcrasher's Avatar
kawcrasher
I can't help on the wiring,but it seems to me the pumps aren't switched at the selctor my 84 f350 will run the rear pump with the key off even if the front tank is on. I won't get fuel unless the rear tank was selected before the key was turned off. When the key is on it will run the pump for the selected tank.
