something i've came across is on the back of the multifunction dimmer (turn signal) there are 3 wiring plugs. 2 big ones and 1 small gray one with only 4 wires going in. I've found a few that that small connector was bad and the connections were loose. Just check the connectors.
I have only one headlight out and the bulb is good. The switch is functioning properly but no power to this headlight on low beam. Hi beam works fine. I thought I remember reaking on a forum that it could be the headlight out" system check printed circuit board. Where is that located?
Thanks for your help in advance
Yeah the lamps out module/LOM is the most likely problem.
Lots of guys have found loose solder joints in the module & simply resoldered them. Sure beats spending 80 bucks for a new one.
As I recall the dash panel just above the center console needs to be removed to get to the LOM.
