Noise on startup
Old Apr 13, 2006 | 09:00 AM
Moose in KY's Avatar
Moose in KY
Noise on startup
My 92 ranger 2.3 liter makes a funny noise while cranking and untill it reaches idle. It only lasts a couple of seconds but is getting really annoying. It sounds kinda like something is grabbing or rubbing metal on metal. Its coming from the front of the engine like a pulley or something. At first i thought it was from the idler tensionor or dummie pulley but after pulling the serpeitine belt off, i discovered that the power steering pump pulley is not like the others. I can move it in and out about 1/8 to 1/4 inch. It's also not as easy to turn as the alternator and water pump (which i don't know if its normal or not, i kinda figure that the power steering should have more resistence to it.)
What i'm asking is should the power steering pulley be able to be pushed in and out a little bit or should it be solild like the other pulleys?
Old Apr 14, 2006 | 03:38 PM
pawpaw's Avatar
pawpaw
The P/S pump shaft shouldn't have that much end play in it.
I'd get that puppy off before it contaminates 7 ruins your P/S rack.
Thoroughly flush the system, before you replace the pump, so any wear metals don't ruin it too.
Let us know what you find.
Old Apr 14, 2006 | 03:57 PM
pintopower8's Avatar
pintopower8
that may be a problem , but i doubt that is whats making the noise. I've had the same noise out of my trucks. I pulled the starter and lubed the front starter bearing. Fixed it right up. Now it has a nice clean vroom when it starts.
SaturnSky11
May 29, 2014 07:32 PM
underp2
Aug 12, 2012 09:00 AM
SmokeBlower
May 24, 2008 11:14 AM
1pump
1978 - 1996 Big Bronco
Nov 11, 2004 11:56 PM
