Offroad & 4x4
I'm all about quality, not quantity
Old Apr 13, 2006 | 05:05 PM
KubotaOrange76's Avatar
KubotaOrange76
Its Comin Right for us!
what sorts of driveline upgrades are you planning to make ivan??
your still running stock 1330 shafts front and rear right?
Old Apr 13, 2006 | 05:11 PM
ivanribic's Avatar
ivanribic
I'm having a local shop build me a 1410 setup for the rear with thick wall tubing. It's the 2 piece shaft so more points for failure. I'll have Jess build the front shaft later in the year when the $$ is floating around. Right now I'm running stock shafts.
Old Apr 13, 2006 | 05:18 PM
KubotaOrange76
hell yea, what wall thickness??
you gonna run a 1350 cv shaft up front? or one of his 42 degree cv's?
my 1350 cv up front from him has some crazy angl capability...before i could bind the stock 1330 cv fairly easy...i cant even come close with jess's shaft
Old Apr 13, 2006 | 05:28 PM
ivanribic's Avatar
ivanribic
Haven't decided on the wall thickness. Basically I'm gonna roll the truck down to their shop and show them what I'm doing and then tell them to build me a shaft that can handle 1200hp. I'll let those guys figure it out from there so if it blows up I can take it back and have them fix it.
The front shaft is some goofy mix of parts. I've got the e-mail somewhere detailing it but basically it's a nightmare to put heavy duty CV's on married 205's with a C6 because of clearance issues. He can do it but it's not cheap. Go figure. I think it was a 1350 combo though. I'm not too worried about the front shaft because it won't be getting hammered unless I'm splitting the power with the rear axle (must resist front wheel drive burnouts) but I'm really worried about that rear shaft with the new engine.
Old Apr 13, 2006 | 05:40 PM
KubotaOrange76
sounds like a good plan....i bet they will go at least 1/8" wall tube out back
come on ivan...whatd you do those twinsticks for.....yes....front wheel burnouts!!
Old Apr 13, 2006 | 08:44 PM
Flareside94's Avatar
Flareside94
Front wheel burnouts WOULD be awesome.
Sounds pretty sweet.
Old Apr 13, 2006 | 09:23 PM
gyger1's Avatar
gyger1
I don't know all the details of what you're running
but when using a large shot (if you guys are serious)
octane can only account for so much. What are you doing
with your timing and what plugs are you going to be running?
Sounds like a fun project. Nitrous is fun on dynos when
you watch your TQ curve shoot up
Old Apr 13, 2006 | 09:50 PM
ivanribic's Avatar
ivanribic
I've got an MSD setup that automatically retards my timing so many degrees when I engage my nitrous. All the safety precautions are covered including fuel pressure shut off. I'll play with the plugs once I've had a chance to run the engine for a while without any nitrous.
Old Apr 13, 2006 | 10:11 PM
proeliator's Avatar
proeliator
Kind of like everytime you get behind the wheel
Old Apr 13, 2006 | 10:16 PM
monsterbaby's Avatar
monsterbaby
Ivan I think your forgetting something on this engine aren't you?
Old Apr 14, 2006 | 02:25 PM
s8whiskey's Avatar
s8whiskey
I know a guy that runs old Prat whittney jet engine plugs on his truck of course its custom but it takes something like 9800 psi to blow em out or somtehing so AKA way to high to ever have that problem
Old Apr 14, 2006 | 06:57 PM
ivanribic's Avatar
ivanribic
Jet engines use spark plugs? That's news to me.
Rob, are you talking about my lack of boost?
Old Apr 14, 2006 | 07:43 PM
  #28
wick246's Avatar
wick246
"Jet engines use spark plugs? That's news to me."
Yep - igniters. That's how they get the initial combustion going on some engine designs. After the engine is started they can be turned off. Kind of like starting a propane barbeque.
Old Apr 15, 2006 | 12:01 AM
  #29
teds74ford's Avatar
teds74ford
Yeah, they are called ignitor plugs. Just a REALLY high tech spark plug. It seems to run ignitor plugs in a reciprocating engine, but if he was convinced he had spark blowout, then that would be the way to go.
Old Apr 15, 2006 | 12:05 AM
  #30
monsterbaby
of coarse I am refering to your lack of boost what else would I be refering too.
