99 SOHC Timing...Recall Question
Your best bet is to stop by your dealer and see if they will help with the cost.
print this and go hit up the dealer
Recall Lookup : FORD : 1999 : EXPLORER
Select a recalls summary to display.
1999 FORD EXPLORER: 00V072000 12314 20000307 ELECTRICAL SYSTEM:FUSES AND CIRCUIT BREAKERS: ...
1999 FORD EXPLORER: 06E026000 33921 20060323 EXTERIOR LIGHTING: ...
1999 FORD EXPLORER: 99V164000 12265 19990629 LATCHES/LOCKS/LINKAGES:HOOD:LATCH: ...
1999 FORD EXPLORER: 00V395000 36621 20001128 POWER TRAIN:AUTOMATIC TRANSMISSION:CONTROL MODULE (TCM, PCM): ...
1999 FORD EXPLORER: 03V281000 12680 20030805 SEATS:FRONT ASSEMBLY:RECLINER: ...
1999 FORD EXPLORER: 99V123000 21189 19990518 SERVICE BRAKES, HYDRAULIC:FOUNDATION COMPONENTS:HOSES, LINES/PIPING, AND FITTINGS: ...
1999 FORD EXPLORER: 99V062001 28758 19990330 VEHICLE SPEED CONTROL: ...
1999 FORD EXPLORER: 03V280000 12678 20030805 VEHICLE SPEED CONTROL:CABLES: ...
I was asking on behalf of a neighbor (mine's a 92 4.0 pushrod). I guess I leave it to him to work out. It's a shame, but it looks like he'll have to spend the big bucks for a repair.
Thanks again.
Here are the only recalls on that vehicle.
03S03 AUG 03 Recall - Speed Control Cable Inspection/Replacement
01B77 OCT 01 Recall - Firestone Tire Recall Supplement
00S46 DEC 00 Recall - Powertrain Control Module Reprogramming
FIRESTONE SEP 00 Recall - Firestone Tire Recall
00B40 APR 00 Recall - Multifunction Switch Replacement
00S04 APR 00 Recall - Multifunction Switch/Harness Replacement
99S18 JUL 99 Recall - Secondary Hood Latch Replacement
99S16 MAY 99 Recall - Brake Line Repair
99S09 MAR 99 Recall - Speed Control Cable Replacement
The Ford owner notification program is nothing more than an offer by Ford to extend the warranty on parts known to fail prematurely. They reluctantly take this step, usually only after a ton of complaints.
There is a big difference. On a recall Ford MUST fix the problem whether your vehicle exhibits the problem or not....doesn't matter how many miles you have on it. On the owner notification program it's basically up to Ford to determine if your problem is related. They may honor the extension or conveniently come up with another cause.
The campaign for the tensioner and intake manifold gasket was 00M12.
There was a campaign for the timing chain guide, campaign 01M01, which extends the warranty to 7 yrs. or 100,000 miles, but only applies to model year '97 and '98. I talked to Ford and they said they will not cover my '99 since my VIN is not covered in the campaign.
