idle rpm's
Old Apr 12, 2006 | 12:56 PM
62Cole's Avatar
62Cole
idle rpm's
i was checking out my shop manual and it tells me to run my I6 223 at 500-550 rpm's at idle. this seems low as im running at about 850 now...what do some of you other guys run your 223'a idle speed at.
Old Apr 12, 2006 | 02:09 PM
hiball3985's Avatar
hiball3985
I run mine at 525, thats about where the generator light goes out
Old Apr 12, 2006 | 09:22 PM
62Cole's Avatar
62Cole
yeah mine goes ou around there too...but the engine seems to kind of bounce around too much. mine seems to stay in better balance with the rpms' at 800...thanks for the reply though
Old Apr 13, 2006 | 08:51 AM
hiball3985's Avatar
hiball3985
it should idle at 500-550 with no problem, you might have a timing, carb idle mixture problem, vacuum leak..etc
Old Apr 16, 2006 | 12:19 AM
62Cole's Avatar
62Cole
My generator light comes on around 725....how can i check for vaccumm leaks ....
Old Apr 16, 2006 | 09:38 AM
hiball3985's Avatar
hiball3985
it shouldn't come on at that RPM, what are you using to measure it???? if it is, you may have a bad of miss adjusted regulator...have you adjusted the points and dwell and set the timing??? do that first, then try your idle speed and mixture screw adjustments..does your engine have a PVC valve between the crankcase vent and intake manifold??? you can check for vacuum leaks by spraying some WD40 around the carb base and intake to head ports and see if theres any change in RPM
Old Apr 16, 2006 | 11:32 PM
62Cole's Avatar
62Cole
im measuring with my tach st up to my ignition coil...i do have the pc valveand i will try you're advice..thank you very much 62Cole
