injectors????????????
Old Apr 12, 2006 | 11:21 AM
Marine1's Avatar
Marine1
I've replaced 2 injectors on my 03 f250 diesel. Now 3 more went out. I have 72,000 miles on it. Does anyone know where I can get injectors for it, so I can save money and do it myself?!!!
Old Apr 12, 2006 | 12:06 PM
waynerb's Avatar
waynerb
I cannot answer your question, however I am trying to get some info on your situation.
What is your engine build date? When did your first injector go south? Do you have an extended warrenty?
I had all 8 of mine replaced recently. They could'nt tell me if they were c94 or c95 injectors that they removed. My engine build date is 06/03. Good luck W.
Old Apr 12, 2006 | 02:33 PM
Colorado-native's Avatar
Colorado-native
Engine should still be under Warranty to 100,000 miles. Your cost $100.
Old Apr 12, 2006 | 02:56 PM
Marine1's Avatar
Marine1
I don't know what the date is , my truck is at the dealer. The first injecter went out about 3 months ago, and they replaced it under warrentee. So I took it back in to the same dealer since the latest injectors went out and they said they slipped up last time and wern't supposed to fix it under my 100,000 mile warrentee. So they are telling me it will be around 1500 dollars to fix it through them.!! So I guess I will save some money and do it myself.
Old Apr 12, 2006 | 04:55 PM
EnviroCon's Avatar
EnviroCon
I'm a little curious as to what reason the dealer gave for denying your warranty claim?
Old Apr 12, 2006 | 06:33 PM
kw5413's Avatar
kw5413
Me too......
Old Apr 12, 2006 | 07:02 PM
DeesO's Avatar
DeesO
Injectors are a internally lubed engine part, and are covered under the 100k warranty.
Old Apr 12, 2006 | 08:35 PM
kubatob7500's Avatar
kubatob7500
Ford Motor Company or Ford Motor Vehicle Assurance Company covers these components: cylinder block, heads and all internal parts, intake and exhaust manifolds, timing gear, harmonic balancer, valve covers, oil pan and pump, water pump, fuel system (excluding fuel lines and fuel tank), high pressure lines, gaskets and seals, glow plugs, turbocharger, powertrain control module, electronic driver unit, injectors, injection pressure sensor, high pressure oil regulator, exhaust back pressure regulator and sensor, camshaft position sensor, accelerator switch.
This was copied from ford site, however, it is for 2005 model year.
I believe your injectors are covered
Old Apr 13, 2006 | 10:22 AM
Marine1's Avatar
Marine1
They told me that the injectors were concidered electrical. So they said it wasnt't covered in my 100,000 mile warrentee.
Old Apr 13, 2006 | 10:33 AM
kw5413's Avatar
kw5413
Your dealer either lied or is stupid or knows not of what he does for a living.
This is in the manual.
http://www.backglass.org/duncan/2003...anty_pages.pdf
Old Apr 13, 2006 | 10:42 AM
150ford's Avatar
150ford
Go to a different dealer. Thats hogwash there covered. Dont spend another dime.
Old Apr 13, 2006 | 11:25 AM
EnviroCon's Avatar
EnviroCon
Wow! I'm amazed they didn't tell you it was the sparkplugs that were causing the problem.
Originally Posted by 150ford
Go to a different dealer. . .
This is probably your best bet. Unless they're the only game in town. Then I would reccomend taking your warranty guide booklet down to the service dept. with you and opening it up to the page that reads "6.0L/7.3L PowerStroke Diesel Engine Coverage". And with a very polite, but serious demeanor, point to the word "injectors" and ask them to verify that is the part they are saying is not covered under the 5yr/100k mile warranty.
Old Apr 13, 2006 | 12:08 PM
kw5413's Avatar
kw5413
And while you are there...tell 'em you want your money back...if you already dropped some on them.
Old Apr 13, 2006 | 02:00 PM
KRDiesel's Avatar
KRDiesel
I have 98,000 on my 03 and They just covered 3 injectors.
I think your dealer was trying to get 1500 out of you.
Old Apr 13, 2006 | 06:42 PM
150ford's Avatar
150ford
Plus 1500.00 off of the warranty. No wonder warranty is so hard to claim on. Sounds like double dipping to me.
