engine performance
Old Sep 25, 2002 | 09:37 AM
boss_351's Avatar
boss_351
engine performance
Old Sep 26, 2002 | 06:35 PM
bubba21095's Avatar
bubba21095
engine performance
I recently rebuilt my 69 300, block bored, crank turned, head rebuilt, new cam(fuel saver) new lifters, engine all new internally, new carb, headers feeding cherry bombs. I have roughly 600 miles on the engine, and have noticed the performance is increasing as expected but the truck is running really rich and has a bad hesitation on take off. Have tried tightening the mixture screw but all this seems to do is make it idle ruff. The timing is set according to the timing marks(the notch on the damper and the marks on the timing marks cast on the timing cover) to 6 degrees BTDC idle set at 600.. Am I missing something or should I continue to work with the screws on the carb, by the way its only getting about 11-13 miles per gallon, any help or suggestions would be greatly appreciated....
Old Sep 27, 2002 | 12:10 AM
krazdndenver's Avatar
krazdndenver
engine performance
Your rich mix could be to the exhaust system. Not enough pipe, and not tuned to the engine.
Robert
Old Sep 27, 2002 | 12:55 AM
bubba21095's Avatar
bubba21095
engine performance
I installed Pacesetter headers and ran 2" dual pipes to two cherry bombs and then out the side in front of the back wheel, should I have ran larger pipes? These are the the sizes of the original pipe and the flange pipe that came with the headers... Appreciate your time any suggestions on how I can get this leaner???? Thanks again...Bill
Old Sep 27, 2002 | 09:44 AM
dla4634's Avatar
dla4634
engine performance
This probably wont help with your mixture but have you considered a hotter ignition system. They usually make a big performance/milage difference.
Old Sep 28, 2002 | 09:26 AM
bubba21095's Avatar
bubba21095
engine performance
Got a Crane XR700 system ordered and on the way, dla4634 think this will make any difference????
Old Sep 28, 2002 | 10:15 AM
mlf72f250's Avatar
mlf72f250
engine performance
You could always lower the carb float height to lean it out a little. I set mine about 1/8" lower than the stock spec in hopes of improving my mileage. It gave me a slight hesitation off the line and I suspect a little better mileage, but it's hard to separate effects. Around the same time I gave it a tune-up, advanced the timing, pumped up the tires, etc., and I maybe went from 7 to 9 mpg. An additional complicating factor is that I tightened the steering and added a sway bar, so I drive a little faster now. ;-)
--Matt
1972 F250 Custom Sport Camper Special 4x2 360 2v C6 3.73
Soon to have a 104" wheelbase as part of a Broncification project
My FTE Website -- http://www.clubfte.com/users/mlf72f250/index.html
My Galleries -- https://www.ford-trucks.com/user_gallery/displaygallery.php?userid=1108
Old Sep 30, 2002 | 07:20 AM
tw's Avatar
tw
engine performance
Have you tried vacuum timing? Sometimes the mark on damper is not exactly accurate. Just a thought.
Tony Warren
Nebraska
Old Sep 30, 2002 | 07:49 PM
bubba21095's Avatar
bubba21095
engine performance
Hey TW,
Whats vacuum timing???? never heard of it, how's it done????
Thanks for the replys....Bill
