be cool rad?
Old Apr 12, 2006 | 02:27 AM
theguy_88's Avatar
theguy_88
Exclamation be cool rad?
i have a 77 f-250 crewcab 4x4 with a/c and a 4 speed manual transmission that i am swaping in a 460 the engine is going to be a mild build will the direct fit be cool rad with eletric fans be enough to cool my truck? im thinking the engine is going to make about 400+ hp befor i put it in any truck and the truck is going to be lifted and have 38 inch tires. dose any one have a be cool rad or is their a different aluminum rad made by a different company.
Old Apr 12, 2006 | 09:46 AM
beartracks's Avatar
beartracks
I have one at about that hp. It works well but you will need both a 16" fan and a shroud. You will probably have to make the shroud as I did.
Old Apr 12, 2006 | 09:56 AM
1975Ford's Avatar
1975Ford
A good cooling fan will also help to keep it cool, you'll find this thread very informative, https://www.ford-trucks.com/forums/s...ght=clutch+fan.
https://www.ford-trucks.com/forums/s...98&postcount=6
Trucks (camper specials) with 460 engines have very good radiators.
-----Buck------
Old Apr 13, 2006 | 10:41 AM
trinogt's Avatar
trinogt
I have a Trailer Special with the super cooling rad (a new one at that, 4 core) and I still run a little warm on 90 degree days, without towing. In another thread, I mentioned I will be installing an aftermarket temp gauge. I can't believe this monster of a rad would not cool a stock 460 well enough.
Replacement is a Modine. The big rad on these 460 trucks uses a different core support with a larger cutout and different mount system, but I think you can make it work with some fabbing.
Mark
Old Apr 13, 2006 | 11:43 AM
1975Ford's Avatar
1975Ford
Originally Posted by trinogt
I ....with the super cooling rad (a new one at that, 4 core)........I can't believe this monster of a rad would not cool a stock 460 well enough.
Mark
Have you tried good cooling fan.
Old Apr 13, 2006 | 01:25 PM
theguy_88's Avatar
theguy_88
i would like to put in an aluminum rad rather than a copper rad to keep the weight down and add some looks.
Old Apr 13, 2006 | 01:59 PM
1975Ford's Avatar
1975Ford
Check out "wizard cooling" for aluminum radiators http://www.wizardcooling.com/gallery.htm.
Check out national Part Depot (our sponsor) For radiators also, under the cooling section catalog.
Hi cool water pumps are also an option.
Electric fans setup with engine fan switch.
Old Apr 17, 2006 | 12:35 PM
theguy_88's Avatar
theguy_88
is this be cool rad enough to cool my truck with a/c or what would i need to do to add some extra compacity or make it work? going to need to order a rad soon to finsh my truck.
Old Apr 17, 2006 | 06:11 PM
buzzbait65's Avatar
buzzbait65
i would say yes, in fact a BE COOL is in the plans for my 460 highboy, aluminum is the better way to go
Old Apr 18, 2006 | 12:04 AM
Bdox's Avatar
Bdox
Use a high volume water pump. The larger radiator has the effect of slowing down the speed of the coolant through the tubes, setting up a laminar flow. The increased speed of flow with the HD pump will generate a turbulant flow through the tubse which greatly increases efficiency.
The high output pump will also increase pressure inside the block, increasing the boiling point around the exhaust ports.
Old Apr 18, 2006 | 08:58 AM
1975Ford's Avatar
1975Ford
this website has some useful information -
http://www.projectresponder.com/be-c...tor~11~157.htm
http://www.projectresponder.com/460-...ump~11~156.htm
http://www.projectresponder.com/fan-clutch~4~105.htm
Old Apr 18, 2006 | 02:16 PM
trinogt's Avatar
trinogt
1975FORD, what do you mean by 'good cooling fan'?
I am using the stock fan, as I do with all my vehicles...
It is a non-clutch-type fan, 5 blade. What would be better? I looked at aftermarket aluminum flex fans, but they look flimsy...
I will try anything as long as it's not expensive... (and as long as my problem isn't just the gauge)
Mark
Old Apr 18, 2006 | 02:24 PM
1975Ford's Avatar
1975Ford
thermostatic clutch fan https://www.ford-trucks.com/forums/s...ght=clutch+fan
Old Apr 18, 2006 | 02:42 PM
biz4two's Avatar
biz4two
Thumbs up Griffin alum Radiator Setup
This is my setup for my mild built 390FE...in my F150 4" lift 33" tires. Works GREAT...and very happy with the results. Especially in the desert SW...with all this heat we have.
Griffin Alum Radiator:
Direct bolt-in. No modifications needed.
Part #: 7-566BW-FAX
Year : 66-79
Model: Truck
Inlet: top right
Outlet: bottom left
Rows: 2 row
Tube Size: 1.25"
Additional Information: Upto 600hp; Trans Cooler
Size: 19.25 X 26 inch core
http://griffinrad.com/
Flex-a-lite Electric Fan:
27" Electric Fan (dual 13.5") Variable speed control operates the fan from 60% - 100% http://www.flex-a-lite.com/auto/html...-electric.html
Edelbrock Aluminum Water Pump.
FWIW...I originally purchased a be-cool radiator...and did not care for the smaller size...and mods I would have to make. Returned...and purchased the Griffin.
Hope this helps...
biz
_______________________________
1976 F150 LWB 390FE NP435 NP205 4x4 3.50s
Old Apr 18, 2006 | 04:56 PM
1975Ford's Avatar
1975Ford
Electric fan setup https://www.ford-trucks.com/user_gal...0&albumid=9107
