spout problem 302
Old Apr 12, 2006 | 01:01 AM
repou's Avatar
repou
spout problem 302
what would cause the engine not to spark with spout in, but if you pull it out it then sparks. What will happen if you just leave it out.
Old Apr 12, 2006 | 07:00 AM
EPNCSU2006's Avatar
EPNCSU2006
The engine will run at base timing all the time if you leave out the SPOUT. I would have the TFI module tested to see if it is bad.
Old Apr 12, 2006 | 09:00 PM
cujo8's Avatar
cujo8
Forgive my ignorance, but what is the "spout" you guys are referring to? When I here the word "Spout" I thing of the "Oil Spout" we used to use for the old fashioned Oil Cans to pour the oil out of them. I still have one of these. Thanks.
Jim
Old Apr 12, 2006 | 10:57 PM
repou's Avatar
repou
The tfi doesn't by any chance have any thing to do with the fuel pumps also does it?
Old Apr 13, 2006 | 12:03 AM
EPNCSU2006's Avatar
EPNCSU2006
Possibly, if it prevents timing signal from reaching the computer. Have you checked for codes in the computer yet?
SPOUT is an acronym for SPark OUTput, which refers to the timing signal from the engine computer to the coil, by way of the TFI module.
