Inconsistent Starting.
Old Apr 14, 2006 | 01:08 AM
thesargent44's Avatar
thesargent44
Thanks for the tips im glad i found this place! my next step will be to test the batteries.
It's wierd because it doesn't happen everytime i go to start the truck.. my dad works at ford and can get me a new starter for $190. so if i eliminate my options that is where i will go next. what is a good price for a CPS?
Old Apr 14, 2006 | 07:02 AM
F350_Hauler's Avatar
F350_Hauler
CPS - between $45 and $75 depending how much of a rush you're in to get it. There are different ones. Just make sure to match the year for your truck.
Old Apr 14, 2006 | 07:55 AM
MikeFromShiloh's Avatar
MikeFromShiloh
I would not think it was weak or bad batteries. I would figure if it was then it would not do anything the second time he cycled the key switch. I would lean more towards a bad switch, clutch or even the key switch. And then I would suggest either the starter or the starter relay. GL
Old Apr 14, 2006 | 08:46 AM
1996pwrstrk's Avatar
1996pwrstrk
When my starter went bad it just wouldn't turn it over fast enough on the first try always had to hit it twice sometimes 3 trys before it would start. But like was said before go get your batteries load tested make sure that they test them one at a time with the cables off.
Dave
