octane questions
Old Apr 11, 2006 | 07:46 PM
NateDog07's Avatar
NateDog07
octane questions
hey guys I have the 300 inline for now (352 is being built as we speak). well let's say I have a half a tank of just regular gasoline (87 or whatever)...I'm just wondering if it would hurt to add another 1/4 a tank of higher octane for cruising around town? will it actually help my motor in any way?
thanks,
nathan
Old Apr 11, 2006 | 08:07 PM
309Ford's Avatar
309Ford
If the motor is stock it really won't help. The compression of the factory motor does not require high octane gas. The EFI stock motor has a bit higher compression than the stock carbed motor, but neither benefits from higher octane gas.
Old Apr 11, 2006 | 08:36 PM
NateDog07's Avatar
NateDog07
but it wouldn't hurt it though, would it? I just want to put some in there and see what it does, lol that's just the kind of dude I am...
Old Apr 11, 2006 | 08:43 PM
Bdox's Avatar
Bdox
You do it then NateDog, but I doubt that your life will be enhanced in any way. In any case it won't do any damage.
Old Apr 12, 2006 | 08:18 PM
NateDog07's Avatar
NateDog07
haha alright, hey thanks guys for the info
Old Apr 12, 2006 | 10:09 PM
N7ghtwolf's Avatar
N7ghtwolf
Why are you throwin a gas hoggin V8 in your truck!
Old Apr 13, 2006 | 03:03 PM
NavyMIDN08's Avatar
NavyMIDN08
while just a 1/4 tank of higher octane probably won't do anything, i found that if i run full tank of high octane with an extra octane booster and fuel system cleaner through once a year or so it helps keep the beast happy. all the octane boosters do warn that they're not street legal, but you're gonna really have to make smokey mad before he tests the octane level of your go juice...
Old Apr 13, 2006 | 03:13 PM
SR_Crewchief's Avatar
SR_Crewchief
Why??? Are you having issues with pinging/knocking? If your stock and not having issues then all your doing is lighting your wallet without need. If you've made compression and/or timing/fueling changes then you may need the higher octane. The thing most people don't understand is that octane is not a performance enhancer.
Old Apr 13, 2006 | 04:18 PM
NavyMIDN08's Avatar
NavyMIDN08
on an engine with a little over 300k, everything has changed. i've found that the system cleaner helps, but the octane tends to smooth out the engine, its not knocking per-se, but it does run smoother with a higher octane.
Old Apr 13, 2006 | 07:22 PM
NateDog07's Avatar
NateDog07
yea, my engine has 46k on it so... I pay for my own gas so it's no big deal about the wallet lightin up... I'm just gonna give it a try.
Old Apr 14, 2006 | 08:03 AM
SR_Crewchief
Navy, sounds like your needing an increase of octane for daily driving for the same reason I do, an older/high milage engine.
Nate, with your miles you shouldn't need the higher octane. If anything it will hurt your fuel economy.
For myself, I tend to stay with the 87 octane until symptoms tell me I'm needing more. Usually when I'm getting close to tuneup time. More often then not I'll get better, long term, results by running an injector cleaner through the fuel system and cleanup the intake systems (filter/throttlebody/etc). Since I'm still stock the higher octane isn't needed do to higher compression and/or timing changes.
Also, since host of my miles are highway carbon buildup is not a major issue. City driving does lend it's self to carbon buildup, as in deposits on non-friction cylinder surfaces, which can cause pinging and/or pre-detination.
Binkowski
49
Dec 2, 2014 07:06 PM
mustange70
Alternative Fuels, Hybrids & Mileage
Apr 4, 2006 05:08 PM
tjay460
General Automotive Discussion
Mar 29, 2006 09:17 AM
PHS79
2004 - 2008 F150
Feb 1, 2006 08:22 PM
ford_prof
Computer Chips & Tuners
Sep 15, 2003 07:45 AM
