starting problems
Old Apr 11, 2006 | 05:32 PM
triton54's Avatar
triton54
starting problems
hey all, its been very useful being a member here and im back yet again with yet another problem. my 97 5.4 xlt 2wd seems to wanna act dead when i try and start it. the other day i turned the key and nothing, turned it off then tryed again, fired right up...but with the what seemed to be dead hesitation. my voltage meter in the truck reads 12-14 range i cant really tell because its marked 8-18. What other things should i look for or has anyone been thru this?
Old Apr 11, 2006 | 07:31 PM
FTE Herman's Avatar
FTE Herman
The key's cylinder perhaps?
Old Apr 11, 2006 | 08:31 PM
triton54's Avatar
triton54
expensive fix? how do i check it?
Old Apr 11, 2006 | 08:49 PM
amm888's Avatar
amm888
not sure if this is your problem, but you might want to start with your alternator and/or starter - you can pull them out and have them checked by an autoparts store.
Old Apr 12, 2006 | 10:50 AM
grid069's Avatar
grid069
you may want to check out the starter motor relay and the digital transmission range sensor as well as the ignition switch because they are all part of the starting system.
Old Apr 20, 2006 | 09:28 AM
triton54's Avatar
triton54
well i went from simple to complex and ended up changing the starter. who in the hell designed these things. almost 2 hours getting the old one out and a mere 25 min. installing the new one. all in all i saved over $100 though and it was a little experiance.
mark227
Dec 16, 2016 12:17 PM
jws4621
Jul 29, 2016 01:30 PM
Supertommy68
Jul 15, 2016 12:49 AM
Enduroman
Dec 28, 2009 11:27 PM
datdawg
Jul 5, 2005 07:15 PM
