Secondary air intake
Old Apr 11, 2006 | 06:49 AM
tpntx's Avatar
tpntx
95 4.9L, anyone heard of this part. It's a metal tube that has six tubes comming off it which thread into each cylinder head. On one end of the long tube there is a big diaphram.
Doing a rebuild and this thing got mangled.
Old Apr 11, 2006 | 07:39 AM
FghtinIrshNvrDie's Avatar
FghtinIrshNvrDie
I don't know if it's right or not, but I think you're talking about what I call the Intake Manifold. I'm not exactly around mechanics, so I don't know proper names.
Ryan
Old Apr 11, 2006 | 08:32 AM
CABROCK's Avatar
CABROCK
tpntx,
the description of the part seems to indicate the intake manifold. Aluminum material, (6) plenum tubes running 1 each to each cylinder. The throttle body (efi) will be attached to the manifold plenum box, (that bid rectangle mass on top) which will then have your air box tube(s), and then finally the airbox with your air filter. If this decription does not sound like your part, we will need more info,
Good luck!
Old Apr 11, 2006 | 08:51 AM
roadsiderob's Avatar
roadsiderob
I think that's your air injection manifold. It's designed to get extra air into the exhaust stream at certain times to help the catalytic converters work more efficiently.
Old Apr 11, 2006 | 09:38 AM
CABROCK's Avatar
CABROCK
Wink
tpntx,
after reading roadsiderob, I have to concur with his analysis, you are probably taking about the A.I.R. (air injection reactor) pipe.
Old Apr 11, 2006 | 10:23 AM
tpntx's Avatar
tpntx
heres a pic
thats probably it A.I.R.
All the ford guy could figure from my desc. was Secondary Air Intake. He even gave me a price 200.00+.
So far this part only comes from ford Im checking salvage yards on line today. I just had to buy a lower manifold because the one on it had the ears broken. Luckily it was only 65.00.
Thanks for your help.
Old Apr 11, 2006 | 10:42 AM
LoosMaster's Avatar
LoosMaster
That is the A.I.R injection rail for emissions control. That thing you call a diaphram is actually a check valve. It should be attached to the exhaust manifold and not the intake.
Old Apr 11, 2006 | 10:47 AM
tpntx's Avatar
tpntx
[and not the intake]
thanks. I'm sure thats where it was which is where I'll put it back
Old Apr 11, 2006 | 11:19 AM
tpntx's Avatar
tpntx
Man! no one has it. even ford has to order it. My brother really f'd that thing up trying to get it loose. It was pretty much rusted in place.
Any tips on a salvage yard I might try. I have several and they all say no way. It' a 230.00 pipe!
thanks again.
Old Apr 11, 2006 | 11:43 AM
LoosMaster's Avatar
LoosMaster
I attempted to remove mine during the overhaul and when one of the fittings started to round off, I left it alone. I knew that Ford would be the only one to have it and their prices are sky high. I had to buy the pipe for the EGR valve and that alone was $80.
Old Apr 11, 2006 | 01:54 PM
CABROCK's Avatar
CABROCK
Talking
tpntx,
page 81 of catalog FD.5 @ LMCTRUCK.COM. For your truck, I think part #42-6031, illustration 1. Does that look like your part?, it's $89.95
Old Apr 11, 2006 | 02:03 PM
andym's Avatar
andym
I got mine from rockauto.com. It was nowhere near $230 and their part fit like a glove. When I swapped motors, mine got mangled too getting it off. It's easy to do.
Old Apr 11, 2006 | 03:06 PM
tpntx's Avatar
tpntx
oh cool! yes that does look like it. 89 bucks I'm all over that.
I can't find it online @ RockAuto. Thanks though.
Old Apr 11, 2006 | 04:02 PM
SR_Crewchief's Avatar
SR_Crewchief
Try a different year. It's called an air injection crossover pipe. You'll find it listed in the emissions sub-section. I was able to find in the 1988 listing. This part should be the same for all 87-96.
a88martinez
Apr 28, 2017 01:19 PM
Kolby Haynes
Mar 10, 2017 09:49 PM
clawsd
Mar 8, 2015 06:54 PM
waterboy_fishing
Apr 25, 2012 10:33 PM
Blitzcraig
Feb 8, 2012 11:18 PM
