HELP!! Dual Tank Selctor Switch
Old Apr 11, 2006 | 06:17 AM
cornhead2006's Avatar
cornhead2006
HELP!! Dual Tank Selector Switch 88 F-150
I have an 1988 F-150 and I believe the fuel selector switch for the tanks needs replaced. All they sell is a "universal" type at the auto stores and they require wiring in. Is an OEM type available other than from Ford? Can you just bypass one tank altogether? Thanks for your help guys!
Old Apr 11, 2006 | 07:35 AM
FghtinIrshNvrDie's Avatar
FghtinIrshNvrDie
assuming the 92-96 fuel switch fits the same, here's a link for that one...
http://broncograveyard.com/bronco/i-...tor_switch.htm
I didn't see on on broncograveyard for the older style.
Ryan
Old Apr 11, 2006 | 07:41 AM
LoosMaster's Avatar
LoosMaster
Not sure but he's probably talking about the DFR(Dual Function Reservoir) that is under the truck and not the actual selector switch.
Old Apr 11, 2006 | 07:42 AM
LoosMaster's Avatar
LoosMaster
Not sure but he's probably talking about the DFR(Dual Function Reservoir) that is under the truck and not the actual selector switch. And the answer to his question is "NO", there are no aftermarket one of that type. All the aftermarket ones require electricity to operate.
Old Apr 11, 2006 | 07:51 AM
cornhead2006
Yes, I am talking about the part that is mounted on the frame rail and has 6 fuel lines in it. I have only heard it referrred to as a switch but that may be wrong. Can you simply bypass this valve/switch and hook lines just to one tank? I think the diaphram has gone bad in it best I can tell. Thanks guys for your help
Old Apr 11, 2006 | 07:58 AM
LoosMaster's Avatar
LoosMaster
Yes, all this does is use pump pressure to select the tank and return fuel. Make sure you properly cap off the tank not in use. What is the DFR doing, leaking externally?
Old Apr 11, 2006 | 08:46 AM
cornhead2006
Best I can tell from what I am experiencing and what others have said it is drawing fuel from both tanks. On start up about half the time it starts fine, the other times takes forever to start and I smell gasoline. Also I think one tank is filling the other as it's level keeps rising without putting in gas. Thanks for the help
Darin1
13
Dec 2, 2024 07:10 AM
spidermantat
Dec 16, 2013 05:22 PM
newportman
19
Dec 27, 2011 10:45 PM
Ole Ruff and Ready
Dec 10, 2010 01:18 AM
72hiboy
Offroad & 4x4
May 16, 2005 01:46 PM
