fuel injector upgrade
Old Apr 10, 2006 | 09:52 PM
amcf150's Avatar
amcf150
Wink fuel injector upgrade
Hi i have a recently rebuilt ford 5.0 in my 1988 f150 port matched intake/ thorttle body and some head work with stock mustang shorty headers. i was offered a set of 8 30lb fuel injectors for 50 bucks i was told they will help in hp but have heared otherwise unless computer upgrades are made. can you please tell me if they will help, i know there a good deal but if they wont help then its a waste. thank you. if i left any critical info out please ask me
Old Apr 10, 2006 | 11:54 PM
EPNCSU2006's Avatar
EPNCSU2006
Unless your engine needs more fuel than the stock injectors provide (which it shouldn't with the modifications you listed), there will be no increase in performance by simply installing larger injectors.
Old Apr 11, 2006 | 07:22 AM
TexasGuy001's Avatar
TexasGuy001
Most likely all that will do is waste fuel. I replaced mine with Ford Racing 19 lbs injectors. This is the factory spec. They have 19 24 30 and so on. The 24 would be a little much the 30 is way too much. Thats my thoughts.
Old Apr 11, 2006 | 11:30 AM
JoeVB's Avatar
JoeVB
Well what you could do is put those injectors in and then supercharge the engine
That would eat up all that fuel being wasted
My $0.02.
Old Apr 11, 2006 | 12:07 PM
BigAlVB's Avatar
BigAlVB
My 392 stroker motor has great fuel pressure but needed more fuel per a dyno test so it was recommended I upgrade injectors to larger than stock, which is 19#. I went with 24# figuring if they are enough for a 460, they should work OK for a 392. No problems thus far. Truck runs strong even with SD instead of MAF. Pulls a 28' 5th wheel in the summer and runs in the dunes with the best of 'em! Heck I can still get 12-14 mpg in OD w/ 3.55 LS gears and 33" tires. (Not when I'm pulling obviously!)
Old Apr 11, 2006 | 08:26 PM
amcf150's Avatar
amcf150
thats what i figured, exactly what i did was gasket match the intake to the heads by reomving all the excess material that made the passages so tiny, did a little work to the inside of the heads where the valve stem passes though the head i took of all the rough edges in the exaust and intake side along with opened up the exhaust port by making it gasket matched and removing the damn smog air bumps, and the t/b is also gasket matched to the intake and stock ford mustang shorty headers ( grinded the hell out of the big old sloppy welds they did on the inside). yeah i figured it would just waste gas and do nothing noticible but take more money out of my pocket. im prolly better of on scrapping for parts to convert to MAF. thanks for your in put guys.
bcboy4ca
Feb 11, 2014 02:03 PM
1986stepsidef150
Aug 11, 2013 01:25 AM
f350rebel7788
49
Apr 2, 2011 12:53 PM
GSXRF250MIKE
Feb 13, 2009 04:51 AM
death
Aug 23, 2004 03:16 PM
