What is this line?
Old Apr 10, 2006 | 03:12 PM
rlp's Avatar
rlp
What is this line?
This line became disconnected when I was checking around the engine for oil leak; hopefully I reconnected it up under the cowl but it was full of oil, which I cleaned. Anyone know what it is for?
what is this line?
Old Apr 10, 2006 | 03:51 PM
subford's Avatar
subford
what is this line?
I do not know on the line but how did you do the "what is this line?"?
Old Apr 10, 2006 | 04:03 PM
lowdownndirty's Avatar
lowdownndirty
full of oil?? do you have a after market oil pressure gauge inside the cab.may be the line to the gauge if its mechanical
other than that and the pic is kinda blurry(cheap lap top) looks like a vacuum line.(the hard plastic type)
Old Apr 10, 2006 | 04:12 PM
andym's Avatar
andym
Subford:
Like this
If you are posting a reply (not a quick reply) there is a button with a globe and two chain links at the bottom. Click on the button, and it will prompt you for the text you want to display and the link you want it to point to. In this case, I just used a link to one of my gallery pics.
Old Apr 11, 2006 | 12:01 AM
EPNCSU2006's Avatar
EPNCSU2006
The line in question looks like the vacuum supply line for the HVAC system. The end opposite of the visible tee should attach to manifold vacuum somewhere.
Old Apr 11, 2006 | 07:05 AM
rlp's Avatar
rlp
Thanks all -I have a stock Ford oil gauge, so must be AC vaccum line. I think it had become disconnected sometime in the past and some oil got up there due to another problem (leaky valve cover gasket).
Subford- as Andym says its a link to my gallery. This is my first time attempting to post an image and I had to research how to do it. Email me if you need help; there's also a Test Forum at the bottom of the Forum List which I used to experiment with before I posted here.
