Upper radiator hose
Old Apr 10, 2006 | 01:16 PM
waldreps's Avatar
waldreps
Upper radiator hose
I have a 2000 Ranger with the 4.0L and 5 speed tranny. I noticed the other day that after sitting overnight, my upper radiator hose was collapsed together. I opened the radiator cap and it sucked in air and popped back open. Is this normal or do I need a new upper hose? With the engine running, it's fine. Thanks.
Old Apr 10, 2006 | 01:30 PM
CowboyBilly9Mile's Avatar
CowboyBilly9Mile
I would inspect the radiator cap to ensure that valve on the lower portion functions properly as well as inspect the coolant return line between the burp tank/radiator for pinching/restriction of some form. Also, look in your burp tanks and at the open end of the hose for any debris that could cause an intermittent clog/restriction.
Old Apr 10, 2006 | 01:32 PM
fordboy_52's Avatar
fordboy_52
sounds to me like ur coolant is low and u need a new cap
Matt
Old Apr 10, 2006 | 01:36 PM
waldreps's Avatar
waldreps
The coolant isn't low, but I will check the hose going to the overflow tank as well as maybe replace the radiator cap. Thanks, any other ideas?
Old Apr 10, 2006 | 01:41 PM
fordboy_52's Avatar
fordboy_52
is the hose showing signs of age? mabey its time for a new hose... i wouldnt exactly worry about it tho. if its sucked together it will open when the water pump starts pumping.
Matt
Old Apr 10, 2006 | 02:11 PM
CowboyBilly9Mile
The check valve on the lower side of your radiator cap will open under virtually no pressure. The pressure (vacuum) required to collapse a radiator hose will far exceed this.
Old Apr 10, 2006 | 05:06 PM
waldreps's Avatar
waldreps
The hose to the overflow is stopped up....I'll have to take that off and clean that all out....Thanks for the help.
Old Apr 10, 2006 | 05:25 PM
RangerPilot's Avatar
RangerPilot
You might flush your cooling system and see if you can get any other debris out...something had to be in there to stop it up.
RP
Zach
99StrokeXLT
Aug 20, 2014 01:00 PM
Haleiakala
6.4L Power Stroke Diesel
Apr 11, 2013 07:06 PM
hhcobra
18
May 13, 2012 03:59 PM
robd928
Sep 10, 2011 06:38 PM
LARIAT 85
Apr 2, 2011 06:14 AM
