Rag Joint
Old Sep 22, 2002 | 10:36 PM
jor's Avatar
jor
Rag Joint
67 F-100 Camper Special
I want to replace my rag joint and have a question. I don't see one available here at FTE. I did find an illustration of one in the Dennis Carpenter catalog but couldn't find it on line. I found one at Mac's but it was like 60 bucks or so. I found a kit at AutoKrafters which is only $9.95. What do I need? (besides more money and more time off from work) Thanks.
jor
Old Sep 22, 2002 | 11:09 PM
Mil1ion's Avatar
Mil1ion
Rag Joint
Check out thee H.E.L.P. section of your local parts house.
You'll find one there.
[font color=red]Dennis
FTE Assistant Administrator
[/font]
[link:www.ford-trucks.com/guidelines.html|Club FTE]
[link: motorhaven.autoanything.com|How YOU Can Support This Site]
http://www.clubfte.com/users/mil1ion/canada_flag_animated.gif
[link:www.clubfte.com/users/mil1ion/Mil1ion.html|My Website,"North Of The 49th"]
Old Sep 23, 2002 | 11:25 AM
mlf72f250's Avatar
mlf72f250
Rag Joint
I bought a kit from H.E.L.P. for around $10, but I'm waiting until I change my master cylinder, as it is square in the middle of where I want to swing my wrenches for the rag-joint fix. Without power brakes it looks like it would be much easier.
--Matt
1972 F250 Custom Sport Camper Special 4x2 360 2v C6 3.73
Soon to have a 104" wheelbase as part of a Broncification project
My FTE Website -- http://www.clubfte.com/users/mlf72f250/index.html
My Galleries -- https://www.ford-trucks.com/user_gallery/displaygallery.php?userid=1108
Old Sep 23, 2002 | 01:58 PM
BB's Avatar
BB
Rag Joint
Whoever came up with those H.E.L.P. sections should be elected president! Do you remember what it was like getting those kinds of parts before H.E.L.P?
Barry
Old Sep 23, 2002 | 03:20 PM
mlf72f250's Avatar
mlf72f250
Rag Joint
Yes! Some days I stand there in the H.E.L.P. section and dream about what I can fix with the stuff there.
--Matt
Old Sep 23, 2002 | 05:07 PM
buzzard's Avatar
buzzard
Rag Joint
"I found one at Mac's but it was like 60 bucks or so."
The $60 part is the whole steering coupler. The $10 part is just the "rag."
Old Sep 27, 2002 | 02:53 PM
Bauld's Avatar
Bauld
Rag Joint
Yes Matt I have a pair of 71's one with and 1 with out PB and I can say without hesitation that the power brake resivior makes changing the rag joint a complete ( insert expletive of your choice here). MUCH MUCH easier on the manual brake truck. I found that using a ratcheting box wrench made the job at least doable and the "pins" are most easily removed with a grinding head on a dremel or like tool. If you find yourself doing the swap before the brakes this info may be helpful.
Amen on the HELP sentiments!
N3
Old Sep 27, 2002 | 11:12 PM
getu12's Avatar
getu12
Rag Joint
Here is the part number.D5TZ-3A525-A Flange and Insulator assembly. Hope that helps
Old Sep 28, 2002 | 10:05 AM
mlf72f250's Avatar
mlf72f250
Rag Joint
Thanks for the tips. Maybe I'll buy one of those wrenches.
Last week at the salvage yard I was pulling a few small parts off of a '72 F350 tow truck and near the missing steering box was a DIFFERENT LOOKING RAG COUPLER. I wouldn't have picked it up, since I already had a kit for mine, but something caught my attention. Instead of having the normal cotton/nylon/polyester/kevlar (or whatever) reinforcing mesh it had a fine STEEL (possibly stainless) REINFORCING MESH. I'm not sure if it's any better or longer lasting, or if it will even fit my F250, but I'd never seen the steel mesh in one before. If I can find a part number after cleaning off the grime I'll post it. Unfortunately, this particular one has a worn elongated hole in it, so I won't use it as is.
--Matt
Old Sep 30, 2002 | 09:49 AM
William's Avatar
William
Rag Joint
I pull the column. Couple of wiring harness plug ins, few bolts, couple clamps and presto out and on the bench. I use the plastic Flange insulator Assemblies and fix this deal once. Really hate doing crap over and over.
William in Atlanta
Old Oct 10, 2002 | 02:45 PM
sb2371's Avatar
sb2371
Rag Joint
jor,
send me an e-mail and I will give the down and dirty on changing it out...... One thing you will more than likely need is Band-aids.
A real knuckle buster, no way around that one.
Strawberry
e-mail: derrick.percival@maxwell.af.mil
Old Oct 10, 2002 | 02:56 PM
sb2371's Avatar
sb2371
Rag Joint
74 F350 SCS
Feb 9, 2014 04:10 PM
74 F350 SCS
Nov 24, 2013 10:57 AM
mahanson
Jan 4, 2008 01:41 PM
jor
User Gallery & Picture Display
Dec 27, 2003 05:23 AM
jor
Feb 24, 2002 09:48 PM
