heater question
Old Apr 10, 2006 | 01:56 AM
Rubiranch's Avatar
Rubiranch
heater question
With the heater turned off there sure seems to be a lot of hot air coming through. I adjusted the hot water vavle and it helped a little, but still a lot of hot air.
Is there a problem? And if there is how do you cure it?
Thanks
Old Apr 10, 2006 | 06:03 AM
jowilker's Avatar
jowilker
Do you run headers on your truck?
John
Old Apr 10, 2006 | 07:25 AM
oldeiron's Avatar
oldeiron
I bought a plastic control valve and it doesn't seem to shut the water off when closed. Or when open.
Old Apr 10, 2006 | 09:20 AM
Rubiranch's Avatar
Rubiranch
Nope, no headers. The hot air comes through the heater. When I adjusted the wate valve the air wasn't as hot but a pretty good draft comes through. I looked inside the duct and the vents seem to move the way they should. When I open the right vent it stops a lot of the hot air coming out of the heater vent.
I think what ever is supposed to stop the air from entering the heated when in the off position is the problem, but I don't know what or where it is.
Old Apr 10, 2006 | 10:20 AM
jowilker's Avatar
jowilker
Just wondering, my truck makes a lot of heat as well. I know adding insulation could help. I'll get around to it one day.
John
Old Apr 10, 2006 | 10:39 AM
Rubiranch's Avatar
Rubiranch
Mine actually has hot air flowing out of the floor heater vent. More than just engine or road heat.
Old Apr 11, 2006 | 02:41 PM
Vern69's Avatar
Vern69
Even with the heat set to low and the fan off I still get heat coming from the floor vent so I just open the fender vents and windows and deal with it. I figure that short of not having a heater at all, that's about the best compromise I've come up with. Crew comfort was down the priority list for these old rigs and since I wan't to keep it as stock as possible, that's just something I'll live with.
Old Apr 11, 2006 | 03:16 PM
Rubiranch's Avatar
Rubiranch
Thanks Vern, I guess everything is the way it was supposed to be. A bit tacky, but I think I will stuff the floor vent with something to block the air flow. On a hot day I really don't care for "extra" hot air coming in.
Thanks or the replys.
Old Apr 11, 2006 | 08:51 PM
oldeiron's Avatar
oldeiron
The heat control doors in the box don't seal very well but if there was no coolant going thrugh the core all you should get is ambient temp. Try pinching off one of the hoses to be shure there is no flow and see how that is.
Old Apr 11, 2006 | 09:18 PM
go_racing84's Avatar
go_racing84
Is there even a heat control door? I was kind of under the impression that the only thing blocking off the heat in these rigs was the valve in the heater hose.
FWIW, I have a new plastic valve in my truck, and I get the "heat leakage" too. In Summer, I just do like Vern69 and open everything up.
Old Apr 11, 2006 | 09:19 PM
LTTLMAN's Avatar
LTTLMAN
There should be a valve in the heater hose going to the heater core. I believe it is the hot/cold control that opens and closes this valve. Sometimes the wire cable will bend and they won't shut completely. I have popped the cable off and closed them by hand. You just have to remember to open it back up in the fall.
Old Apr 12, 2006 | 01:14 AM
Rubiranch's Avatar
Rubiranch
I did adjust the cable that opens and closes the water valve, helped but didn't cure it. i would like to stop the flow of air.
Maybe thats why you see soo many older vehicles with manual water shut off valves in the heater hoses.
Old Apr 12, 2006 | 01:27 AM
LTTLMAN's Avatar
LTTLMAN
I know my '71 would still put out some heat with the valve all the way closed. However my '70 & '72 wouldn't. Maybe the shut off valve is worn and some hot water gets through.
