302 ?
Old Apr 9, 2006 | 10:44 PM
fordfanwv's Avatar
fordfanwv
Post 302 ?
i have a 1989 f150 4x4 i was wondering what other heads can i put on a 302
block and i have a vacum leak the line is yellow on the passanger side any idea were it goes on can anybody send me a copy of a veci pic?
Old Apr 10, 2006 | 06:54 PM
jade79's Avatar
jade79
There are quite a few heads availiable for the 302. It's basically a matter of how much are you willing to spend, how much power are you looking for, what rpm range, aluminum, cast iron etc. Give us a few more details and we could offer a few suggestions.
Old Apr 10, 2006 | 10:53 PM
fordfanwv's Avatar
fordfanwv
ok im moving this summer ti indianna and i want alittle more power, torqu, and i want to keep this as cheap as possible
Old Apr 11, 2006 | 04:18 PM
jade79's Avatar
jade79
If you're not looking to spend a whole lot of cash, here are my suggestions: (all 3 are cast iron and were used on Ford production vehicles)
Since your truck is an 89, it probably already has the E7TE heads. You could consider having them ported, which would help alot. Check out this website for details, www.thumperoforangepark.com He's a nice person to deal with and his work is well known with the 5.0 mustang crowd.
You could check into a set of GT40 heads. They offer improved flow over the stock E7's but have a larger combustion chamber which may reduce your compression ratio. They also have larger valves and cause piston to valve issues if you are running a radical cam. They were used on 93-95 Mustang Cobras and Lightnings as well as late 95 to early 97 Explorers.
The GT40P heads flow the best out of the 3 mentioned here. They have the smallest combustion chambers, the larger valves and were used on mid 97 to 2001 Explorers. The spark plugs are angled differently on these heads and can cause issues with them being too close to the header tubes. Special headers are available but are kinda pricey. Some people have made the standard long tubes work by modifying the tubes.
