drive shaft
Old Oct 13, 2002 | 01:01 PM
skinnerdom's Avatar
skinnerdom
drive shaft
i have a 1970 ford f-100 short bed that had a 300ci 6cyl and a c-4 tranny, im putting a 1978 400ci v8 with a c-6 tranny in it that was a long bed need to find a drive shaft,short beds are hard to find in junk yards around here, any one know the length of the drive shaft for
a78 short bed so i can get one made or is there any other ford that mite have the shaft i need . i have the 78 doner truck so if i need to adapt any parts i can just need help on the length
SKINNER:-staun
Old Oct 13, 2002 | 01:39 PM
Jimbare's Avatar
Jimbare
all alone in the world
drive shaft
grab a tape measure, measure from the tail of the tranny to the yoke on the rear end. subtract 2.5 inches, and hit the junk yards. 65-72 are definetly the same, if some one has changed to a later model tranny. a lot of cars will have the right shaft in them. usually 4 door cars had a shaft that will work.try to stay in the mid60s-mid70s. galaxie, ltd and the like. a lot of yards have driveshaft piles, go thru it and see what you can find. one more thing, and it is hard to say, check the chevys also. they used the same joint as ford in the earlies.
Old Oct 13, 2002 | 08:54 PM
skinnerdom's Avatar
skinnerdom
drive shaft
thanks for the help
Old Oct 13, 2002 | 11:33 PM
comet's Avatar
comet
drive shaft
If you already have a long-bed drive shaft, you could take it to a driveline shop and they will shorten it for you if you can't find one in the junk yards. Much easier and cheaper to shorten one than lengthen, so measure twice, cut once!
Old Oct 14, 2002 | 04:23 AM
gtex's Avatar
gtex
drive shaft
67buckeyeF100
Aug 24, 2014 10:00 PM
Wagion
Jul 21, 2010 12:48 PM
Toymakerz
Oct 13, 2007 09:34 PM
Keone
Mar 24, 2005 02:50 PM
skinner
Engine Swaps
Jan 12, 2005 11:06 AM
