Sponsored by: Auxito
do i need a very large hammer
Old Apr 9, 2006 | 04:16 PM
toongran's Avatar
toongran
i have 1998 ford f-150--4.6 was running rough codes showed egr needed -replaced it and sensor--still rough--replaced 2 coil packs--plugs and wires--fuel filter-- removed throttle body cleaned port to egr--truck now wont start!!!!--checked shut off in door pannel--checked gas cap-tryed different keys--any suggestions did run --im after very big hammer
Old Apr 9, 2006 | 05:17 PM
projectSHO89's Avatar
projectSHO89
Be specific about your current fault....
Old Apr 9, 2006 | 05:21 PM
toongran's Avatar
toongran
wont start now-- turns over acts as if not fireing checked plugs and wires-- checked ports for water from heater hose when removed--only think i have had that wont start after new plugs im stumped
Old Apr 10, 2006 | 01:46 PM
jrlowscot's Avatar
jrlowscot
After you changed the fuel filter did you cycle the key on and off to prime the fuel system? I guess you checked to see if your wires are hooked up correctly, remove a plug or use and old one to see if it is getting a spark. check for loose connections where you were working.
Good luck
Old Apr 10, 2006 | 02:59 PM
toongran's Avatar
toongran
yes- have checked plugs and wires several times-- rechecked order of wires --fuel pump seems to be working ok --have fire at plugs
Old Apr 10, 2006 | 04:10 PM
todd31277's Avatar
todd31277
do you smell gas like its flooded when you crank it over. does it hit any at all.
Old Apr 10, 2006 | 06:29 PM
toongran's Avatar
toongran
when cranking you can tell gas is getting to throttle body (you can smell it)-no it isn't trying to start just tirns motor over
Old Apr 13, 2006 | 04:18 PM
todd31277's Avatar
todd31277
what kind of plugs did you use. back when autozone started pushing boush platniums, i worked there and had a guy come back with a new set that his chevy did the same thing. wouldn't start after the plug change. put a set of ac plugs in his chevy started right up.
