Garage & Workshop Tips & Ideas for the garage or workshop. No Truck Tech Discussion
Garage Heater
Old Apr 16, 2002 | 10:56 PM
  #31
pcmenten's Avatar
pcmenten
Garage Heater
Gator, is there a heat exchanger on the waste oil furnace? Reason I ask is that I've heard that there are toxic metals in waste oil. I already spend too much time in contact with heavy metals and such to want to add them to the air.
Old Oct 16, 2005 | 03:39 PM
  #32
afinepoint's Avatar
afinepoint
Anyone hooked a wood stove into the existing home furnace ducting? They must make kits for this.
AFP
Old Oct 16, 2005 | 05:01 PM
  #33
TK70Ranger's Avatar
TK70Ranger
I can't remember the brand but we have this space heater called a "Big-Buddy". Runs on two of those small Coleman propane cylinders (like used in those little camp stoves). Puts out quite a bit of heat. Its good as long as you have some ventilation, has a built in fan that you can turn on or off. It says it's safe for indoor use, but I can tell you from experience, the room quickly fills with gas and I wouldn't recomend it.
Old Oct 17, 2005 | 07:45 PM
  #34
luvthesnow's Avatar
luvthesnow
Originally Posted by 51frrdtrk
Right now i'am paying .95 cents for a gallon.
For Propane??? In Michigan?? Right now?? I want your supplier man! In MN I pre-bought in August at $1.36!!!!
Old Oct 17, 2005 | 10:27 PM
  #35
budman-mo's Avatar
budman-mo
I had the same thought...95 cents!
Then I noticed that post was from 2002.
I like LP for heat, I have a hanging furnace in my shop. I used to have a 82 Gal pick up truck motor fuel tank but finally hooked it up to my house tank for convience.
My brother had a cheap set up in his last house, he bought a small take out electric furnace, stuck it in one corner with a deflector/duct and he had instant heat. He had a large 2 car so you only had to run it for a couple minutes and it was warm. All it took was 220 power and 50 or 75 bucks.
Old Oct 17, 2005 | 10:35 PM
  #36
Torque1st's Avatar
Torque1st
Posting Legend
Sometimes you can find old used furnaces at garage sales or at construction sites. Just have them checked over good and set up right to operate safely.
Old Oct 17, 2005 | 10:55 PM
  #37
luvthesnow's Avatar
luvthesnow
I see I'm the putz again. Thanks for pointing that out.
WilleyJoe.62
Car/truck Buying Advice
Jun 24, 2015 12:37 PM
blueeyedfordguy
Garage & Workshop
27
Feb 17, 2014 11:23 PM
swillotter
25
Nov 4, 2006 05:04 PM
66gpw
Jul 9, 2006 01:24 AM
zuikoman
Garage & Workshop
25
Jan 19, 2005 05:26 PM
