not getting fuel?
Old Apr 9, 2006 | 12:25 PM
78ford351m's Avatar
78ford351m
not getting fuel?
I poured gas down into the carb on my 78 351m and it starts for about 3 seconds and then wont' start again unless I pour more gas down into the carb. There are two spots on the back of the carb, one looks like vacum and other gas. How can I check if the fuel pump is running? any tips?
Jason
Old Apr 9, 2006 | 12:42 PM
rchewitt50's Avatar
rchewitt50
If the fuel pump is running it will draw/push fuel out of a gas can IF if is primed. You can most likely fit a good size can down there too without doing anything too special. You need to first check the fuel passages to make sure they are not blocked. Also to note. In 2 of the 76-78 F250's I have seen there was a tear in the hose between the tank and the steel line that runs up the frame. This caused serious confusion while blowing the hose back from the pump, becuase I could hear the air coming out, I thought it was clear. Two fuel pumps and much monitoring of this site later it really was only a $1.00 section of hose and clamps. A friend had the same problem, he went right to it and found the tear. If you can blow the hose clear and know that it is not blocked/intact you are most likely buying a pump.
I switched out to an electric to prevent the commom blow-by that occurs with the pump passing fuel to the case. A little more but I think worth it.
Old Apr 9, 2006 | 12:43 PM
rchewitt50's Avatar
rchewitt50
Also, just follow the hose from the pump to see the fuel inlet.
Old Apr 9, 2006 | 01:47 PM
78ford351m's Avatar
78ford351m
Well it seems part of the problem is my exhaust on the passenger side is spitting out anti-freeze and oil. Time for a rebuild anyway. Last time it kicked over it had a small backfire, so I'm guessing my dizzy is probably off as well. I'll check the lines and pump. Thanks guys!
Old Apr 9, 2006 | 01:51 PM
53fatfndr's Avatar
53fatfndr
If you have antifreeze and oil coming out of your tailpipe, then you probably have a blown head gasket......
Old Apr 9, 2006 | 01:53 PM
78ford351m's Avatar
78ford351m
That's obvious, but the truck should still run.
Old Apr 9, 2006 | 03:30 PM
rchewitt50's Avatar
rchewitt50
Well look at it this way, if you just let it run out of oil and anti-freeze, it wont try to burn it anymore. Wait! That only applies to the inline 6 engine.
Well have fun with that 351m. I just finished a 400 and it runs like a champ. Word of advice, don't mess with the bottom end much. Stick with the carb, intake, cam and rockers. That bottom is happier just the way it is.
