cam help 351w engine change
Old Apr 9, 2006 | 09:20 AM
camarokid81's Avatar
camarokid81
i have a 92 ford e250 van with a 351w that has speed density injection. i bought a 96 351w roller motor that came from a mass air van. will the stock roller cam in the 96 engine work with the old SD efi computer? need to know now while i have the engine out. van will be changed to mass air in the future once i get a hold of the mass air air cleaner, pipes,mass sensor, the bungs installed in the y pipe and a 95-97 e40d trans (because of the solenoids in the trans are different). just want to know if i can install the engine with stock roller cam or does it need to be changed. i have mass air ecm ,complete wire harness,most sensors, but need parts above to complete it
Old Apr 9, 2006 | 07:42 PM
EPNCSU2006's Avatar
EPNCSU2006
The stock computer should be able to handle that cam just fine.
Old Apr 10, 2006 | 03:18 PM
MrG4x4's Avatar
MrG4x4
I agree, if you keep everything stock on the roller motor the SD computer should have no problems.
jk89cat
17
Apr 18, 2026 06:40 PM
speedemon1084
Aug 22, 2015 09:07 PM
jberylecrider
33
May 24, 2015 11:49 PM
neil 95 e350
S. California Chapter
Aug 27, 2012 11:09 PM
82ford302
1978 - 1996 Big Bronco
May 17, 2008 01:00 PM
