rustbullet
Old Apr 9, 2006 | 05:47 AM
army_guy25's Avatar
army_guy25
Question rustbullet
if i was reading there sight right...they say little to no preperation...just big flakes of rust knocked off then you apply it. and it fills in pinholes etc. right? then after rustbullet coat you will have a smooth body prepped and primed basically ready for paint then? or do you hafta do bodywork bodywork bodywork then rustbullet then paint....i dunno HELP
Old Apr 12, 2006 | 12:56 AM
roger dowty's Avatar
roger dowty
theres some decent threads that discuss what your asking- I'd search the forum. Best way to search is to go advanced and type in: +rust +bullet try searching titles first and all thread content second.
BTW- welcom to FTE! I'm not real familiar with rust bullet but do know the process and other good products. You do need to get rid on layered rust (obviously layered rust protect rust underneath and possibly provides air pockets) and you really should grind down the rust some to make sure your down close to the root of it- not a ton of grinding but it is easier than using a wire brush anyway and you will be amazed at what you get off and how much is left. Then step 2:
Kill the rust with some ospho type chemical. I really like POR 15 and it has a 'metal prep' that kills the rust and etches metal that you ground down into so the special paint will work. Then degrease and put on the top coat of choice. Like I said I like POR 15 cause it describes the whole process and provides the product...I would not use a product that is too simple. Again, I'm not real familiar with rust bullet.
rust is cancer..it takes very, very aggressive treatment.
