Welcome to FordTrucks.com! We are the Internet's Premiere Resource for all things Ford Truck and SUV related!
We are happy to have you! There is a ton of great info on this site. But, before you go snooping around there are a few things you need to do first.
1) Want to meet or talk to other members in your area? There are Provincial, State and International Chapters located near the bottom of the main forum page.
2) Before you post a thread asking a question be especially aware of where (what forum) to place it in. FTE is HUGE! Make sure you read the Read First: at the top of the forum before you go posting.
Click HERE to find the answer regarding your question.
Psssstt...The Engine Swaps Forum.
3) And finally you should review the Guidelines. They will kind of give you an idea of what is and isn't allowed on this site ("The Rules").
And that is it. I hope you enjoy the FTE "Experience"! This is a great place and we have lots of fun while exchanging valuable info. If you have any questions or problems do NOT hesitate to contact me. Just click my username then send me an email.
the 352 was not a option for your truck the 352 was last used in 67 but possible for one to be swapped in. unless you are seeing the 352 mark on the block and assuming its a 352 in which case the 352 is just a casting mark on FE engines. the 351 will not bolt up to anything you have in there and will require a lot of work.
thanks very much for the reply ford390gashog. is it that the bellhousing wont accept the 351m or the motor mounts or both? and do you know of a quick way of identifying the engine in this truck, other than measuring the stroke?
I would start a thread in the FE forum about engine size. They will be your best bet and maybe Matt could move this one to the 73-79 forum so you will get some more help.
The bellhousing needs to be changed along with the perches and motormounts. you will aslo need a new radiator and all front acc. the 351m swap is a backwards swap. you will have a lot less power than you had with the FE the m is a smog dog in stock forum and not worth the hassle.
thanks 4 the advice. i now have a direction. the unknown engine in the truck is getting coolant in the oil and has a baddly leaking rear seal but maybe i should go that route anyway. easier than fighting with the smog dog. i appreciate the response.
