Garage & Workshop Tips & Ideas for the garage or workshop. No Truck Tech Discussion
Extra key
Old Apr 18, 2002 | 05:56 PM
DailyDriver's Avatar
DailyDriver
Extra key
Not really a tip for the garage but may be useful and give you peace of mind. For those of you who have an older truck that doesn't have a hood latch/lock on it, you might want to try this. Ever lose or mis-place you keys? How about when you're way out in the boonies? You may not want to trust those magnetic key boxes to keep a spare key in, as it might fall off if you should hit a big bump or go off roading. Just tape a spare key to one of your truck water hoses. Use black electrical tape or duct tape and it looks like someone just tried to fix a hole in the radiator hose. If you loose your key, pop the hood, remove tape and there you go. I would suggest the bottom hose.
Old Apr 18, 2002 | 07:07 PM
wolfmanagh's Avatar
wolfmanagh
Extra key
been there done it.
I used extra wire and tied it to a bunch of other wires and tucked it way down out of site.
Right now I was thinking of a unlock botton in the the "somewhere" and keeping a spare key inside "somewhere".
The company had bought a used 99 clubwagon and just resently we changed a flat and found a spare key back by the jack. looks like someone else had the same problem.
Old Apr 20, 2002 | 09:41 PM
MustangGT221's Avatar
MustangGT221
Extra key
If you have to pop the hood to get your key, how are you gonna pop the hood with the doors locked shut?
Primary rig is:
95' F-150 EB 300/6 5 spd with 4" Superlift, MSD, Ram Air, Gibson Exhaust, 32" BFG Muds
NEW PICS IN MY GALLERY!! :-)
Then theres:
88' F-250 Superduty 351 + c6
95' Mercury Cougar 4.6L V-8
80' E-350 300/6 and a
3 spd column shifter baby. Top speed, 65mph, Go Baby Go!
The newest addition to the Ford family is a 99' Mustang GT 4.6L
Old Apr 20, 2002 | 09:55 PM
wolfmanagh's Avatar
wolfmanagh
Extra key
No ofense intended. Read DailyDriver's post again. we were refering to older ones when they opened only from the outside.
And I suggested a button somewhere on the outside of the vehicle in a conceled location to get in.
Right now I jimmy the employees cars open when they lock their keys in them.
Old Apr 21, 2002 | 05:52 PM
Avanti's Avatar
Avanti
Extra key
On ones that I can't pop the hood, I put them underneath the bumper, secured by a twisted wire in a small cranny. On another I put the door key unerneath a bed mat and hide the ignition key inside the cab.;-)
Old Feb 9, 2003 | 10:20 PM
jrs_big_ford_f150's Avatar
jrs_big_ford_f150
Extra key
Heres a good spot. Inside the washer fluid tank. On my truck there is a screen to keep out debris from getting in the tank. And its the perfect size for the square headed key. The door key is hidden on the frame rails.
Old Feb 10, 2003 | 02:55 AM
DainBramage's Avatar
DainBramage
Extra key
I keep a spare key in the console. But, for the doors, I keep a lockout tool I made (the first time I locked myself out) under the bedliner..
It's good to have a friend that's a locksmith, you can learn some stuff
Old Feb 10, 2003 | 06:52 AM
TheWiz427's Avatar
TheWiz427
Extra key
Why not just keep a spare key in your wallet.It has worked for me for years.
Old Feb 10, 2003 | 08:14 AM
Buckarcher's Avatar
Buckarcher
Extra key
That works well until you don't have your wallet, or its sitting in the console, locked inside the truck.
Old Feb 10, 2003 | 09:36 AM
dbrown13's Avatar
dbrown13
Extra key
I carry TWO sets of ignition/door keys. One in each pocket, never failed me yet.
Old Feb 12, 2003 | 04:14 AM
1993F150XL's Avatar
1993F150XL
Extra key
dbrown13, what if you forget your pants? Sorry, I couldn't resist.
Old Feb 15, 2003 | 03:10 PM
mick460's Avatar
mick460
Extra key
I put one behind the liscense plate thru the bolt or screw. Usually a coin is all you need to take out the screw. We don't live in a metro area where license plate thief is a problem thou.
Old Feb 15, 2003 | 03:22 PM
Mil1ion's Avatar
Mil1ion
Extra key
I was thinking about getting one of my ears pierced and then use a spare key as an earring.
Old Feb 15, 2003 | 06:14 PM
1pump's Avatar
1pump
Extra key
I just wire an extra key up near the back end of the frame by my receiver hitch. I use stainless wire and an aluminum key so it doesn't rust. The bummer is having to fish for it in the rain with all that road grime underneath.
Old Feb 21, 2003 | 09:58 AM
khmorse's Avatar
khmorse
Extra key
W/my expedition I have a coded pad on my drivers side door, so I can keep one inside if need be. But, for p/u's, a good place to put one if you have a bed liner, is to hang it from one of the tie down hooks inside the bed so that it gis hanging between the bed liner and bed. Just reach in the hole and pull it out if you need it.
