Sponsored by: Real Truck
Warning Chimes Questions
Old Apr 8, 2006 | 01:45 PM
Willie61's Avatar
Willie61
Unhappy Warning Chimes Questions
I have a 2000 Ford 250 supercab. When I am driving down the road a chime comes on and rings 5 times. Silent for 5 second and does this again . After five times it quits. I cannot find anything in the owner guide. I called the dealership and it being Sat. their service dept. is closed. Any help would be appreciated.
Old Apr 8, 2006 | 01:47 PM
blueeyes2478's Avatar
blueeyes2478
I would say its the seat belt minder.
Old Apr 8, 2006 | 02:06 PM
Willie61's Avatar
Willie61
I have checked that along with everything else. The dummy lights on the dash tell me nothing. Appreciate the response though
Old Apr 10, 2006 | 06:49 PM
ryaneverk2's Avatar
ryaneverk2
I think this thread may be the answer:
https://www.ford-trucks.com/forums/s....php?p=3545574
Check out the first post... sounds like the same 5-beep problem.
Old Apr 10, 2006 | 08:20 PM
Willie61's Avatar
Willie61
I think you are right. The light is not on as usual. And the beeping is the same 5 at a time then stops after doing this for 5 times. I will call the dealership and thanks a lot.
Old Apr 10, 2006 | 08:51 PM
ryaneverk2's Avatar
ryaneverk2
You're welcome. Hope it turns out to be something simple (could be a burned out bulb causing it) and not something expensive like a new air bag.
C-Level Lawns
Oct 16, 2011 06:50 PM
MarkD_Albany
Mar 23, 2011 03:37 PM
BroncoScott
Sep 27, 2007 04:06 PM
maplelakeduckslayer
1997 - 2003 F150
Sep 10, 2007 05:06 PM
Mosh
Jan 28, 2004 08:06 AM
