I'm actually working on the same project! That's the reason I knew the 15" Rim size. I have a 1990 Ranger with the 14" Rims and would live to run a 16" late model Escape or Explorer rim. All I know is the bolt circle size and that the pattern is common. We can even run Jeep wheels. The problem is with the offset. I can't find that information anywhere but I'm still trying. I'll post it as soon as I can find it. My inspection is up in August and I need tires so that is my deadline. I'm about to resort to crawling under trucks with a tape measure!
Wouldnt the newer 16" rims work on the Ranger after all its practically the same truck......im guessing on this LOL keep us posted.....Ill also try to see if I can figure something
I'm sure someone makes an aftermarket but I like the factory five spoke allows or even the silver clear coat. Either 15" or 16" would be OK and I'll will buy a tire with the same OD as the factory 15" TIRES that came on ranger 4x4's. That way I can swap out the speedo gear for a easy fix.
