Need help!!
Old Apr 8, 2006 | 07:10 AM
six7seta's Avatar
six7seta
Need help!!
alright the guy who had the 84 bronco before me had a belt for the alt that was too big, so he rigged it to work, but yesterday it popped off and the truck backfired and died. I got a new correct sized one on, battery charged, but all its doing it cranking but not starting. it has spark and fuel so Im out of ideas. any thoughts?
Old Apr 8, 2006 | 08:24 AM
Pkupman82's Avatar
Pkupman82
Fowled plug(s) possibly?
Old Apr 8, 2006 | 10:21 AM
six7seta's Avatar
six7seta
maybe, im going to pull the plugs today when im off work incase i flooded the motor. atleast i was on my street when it died
Old Apr 8, 2006 | 11:48 AM
Bdox's Avatar
Bdox
Check to see if that belt could have damaged any wiring when it came off.
Old Apr 8, 2006 | 02:37 PM
six7seta's Avatar
six7seta
all the wiring seems to be togather... is it possible that its just a weak coil?
Old Apr 8, 2006 | 02:53 PM
Bdox's Avatar
Bdox
Was the backfire an intake or exhaust backfire?
Pull a plug wire to check for spark. Just back it out to see if you can hear the spark snap when it is cranked.
Old Apr 8, 2006 | 10:32 PM
fordflaresides's Avatar
fordflaresides
Where are you checking for fuel?, are you actually looking down the carb. and snapping the throttle or did you just check to see if the carb is getting fuel? The backfire could have blown something inside the carb.
Old Apr 9, 2006 | 12:49 AM
six7seta's Avatar
six7seta
i was looking down the carb to check for fuel
Old Apr 9, 2006 | 08:18 AM
Pkupman82's Avatar
Pkupman82
Are you getting a big blue spark on your plugs or a gold colored one? If it's gold you could have a weak coil or bad ground connection somewhere.
Old Apr 9, 2006 | 09:01 AM
havi's Avatar
havi
I'll have the Roast Duck
recheck your timing.
Old Apr 9, 2006 | 12:58 PM
5_labsownus's Avatar
5_labsownus
Does the engine sound funny when you crank it? If so pull the dizzy cap and crank it and see if it turns! you may have broke the timing gears!
Other wise back to basics: spark, fuel and timing!
Rod
