Battery not charging
Old Apr 7, 2006 | 09:51 PM
Nushman's Avatar
Nushman
A problem recently surfaced in my '81 f-150. My battery isn't charging when the truck is running. My battery is less than a year old and I just changed the alt. I checked over the wiring compared to my Haynes manual and the only thing that didn't seem to match was the feed from my voltage regulator marked 'I' aparently is supposed to run to bat+ at the starter relay. Mine however, runs through my firewall with a mass of other wires. These then go up into my dash. Can anyone account for this discrepancy? Should I try connecting 'I' to my bat+? This problem just popped up on it's own and I'm about to take it in for a diagnostic.
Old Apr 8, 2006 | 12:44 AM
fordflaresides's Avatar
fordflaresides
Since the problem just recently started happening it's probably not the wiring routing, could be a new open or short but doubt it's the wiring routing. You might want to test the voltage regulator, I had mine go bad which caused a charging problem. Voltage regulators are commonly overlooked.
Old Apr 8, 2006 | 05:18 AM
srercrcr's Avatar
srercrcr
Clean all connections that battery cables touch.
2006 - 1981 = 25 years.
Plus, remember Rule One....it's usually the simplest things.
Old Apr 8, 2006 | 08:27 AM
Pkupman82's Avatar
Pkupman82
I like to use dielectric grease on all electrical connections that use plugs.
Old Apr 10, 2006 | 11:21 AM
300I6VAN85's Avatar
300I6VAN85
Chased my tail on battries charging twice. A Corvair got a complete new motor wiring harness before I was done. The problem was in the "new" rebuilt alt. Someone forgot to place a nut inside the alt on one of the wiring post. The alt worked ok at low speed and on test bed. Grounded/arked out when it got hot. Tuff to find that problem.
The other 64 Ford van problem was a old battery. I installed new batt cables and I forget what else. It's been 26 years ago. Any way it was the junk in the bottom of the old batt. It would sometimes short out the other plates. Replaced the batt and things were great.
Old Apr 11, 2006 | 01:36 AM
83Van's Avatar
83Van
As others have said, double check your battery terminal connections, the chassis ground, and the alternator output wire. Even if the battery is only a year old you should check the water level in the cells. Do that and still nothing... have your alternator bench tested [most auto parts stores will do it for free] and replace the voltage regulator [they're cheap, about $12].
If your alternator is "dead" it's probably just worn out brushes. You can replace them yourself for about $4 in parts.
Old Apr 11, 2006 | 04:17 AM
Torque1st's Avatar
Torque1st
Posting Legend
Moved to proper forum.
Old Apr 11, 2006 | 07:39 AM
subford's Avatar
subford
I would not believe anything in a Haynes Manual.
The "I" wire never goes to the Battery.
Since you said the "I" wires goes to the firewall that means you have an Indicator Light.
Here is a diagram that would be close.
Old Apr 11, 2006 | 07:48 AM
subford's Avatar
subford
Now for the problem.
You should have the following:
Unplug the Voltage Regulator.
The "I" wire should have power on it with the key on and no power with key off.
The "A" wire should have power at all times.
The "BAT" wire at the alternator should have power at the Alternator at all times.
With your test light check the above and one of the items will be wrong, let us know what you find and we will help you from there.
If you do not have a test light get one.
Improv101
Dec 1, 2024 10:06 PM
Ford Goblin
25
Jul 21, 2015 11:44 PM
reverendxlt
16
Nov 21, 2011 07:37 PM
RJR99SS
Apr 6, 2011 04:04 PM
Sillbeer
Electrical Systems/Wiring
25
Dec 7, 2010 08:11 AM
