KB is it just a matter of gage readings? Or do you have some power or suspicion of loss of power problem you are chasing...
Most of the time automotive gages are not very accurate at all but are still useful for general relative reference. In other words it isn't too meaning full if the Gage reads 200 degrees (or what ever) if the true temp is 208 degrees and each degree of raise or drop is within 1 or 2% of a real degree. To make an electrical gage real accurate requires a adjustable sending unit or gage movement spring setting. Also my experience is that the most accurate portion of all electrical gages in in the mid scale area and gets very inaccurate at either left or right max or min portion of the scales. So for a 32-35 psi up to 47-50psi desired spread you need the 30 to 60 PSI in the center and thus should have a 0 to 90 psi gage preferably a full 270 degree sweep type.
Most of the time mechanical are much more accurate...but caution... mechanical fuel pressure gages are very expensive and for my money are not worth the added expense
Is your regulator Accurate? Adjustable? Years ago I over pressurized and used a regulator for feeding Holly carburators... needed to reduce 35 psi (high flow) down to 11 PSI... I finally found ( after several fixed pressure styles that did not have any accuracy) a Acell(sp?) brand variable unit that did the trick
I'm experiencing a slight loss of power, slight enough that most people wouldn't even realize it, but I do. I have too much money invested in this thing to have it not producing the power it is capable of. Do you know if anyone makes an adjustable pressure regulator for the Triton motors?
I think you should call Bob Kennedy at: http://kennedysdynotune.com/
I know he used to be a KB dealer and installer. I bought his water injection kit and it works great.
When I was shopping around for a s/c I spoke with Bob but ended up getting the kit directly from KB. Once I get it back on the ole Mustang dyno and get some fine tuning done it should be good to go. I just wish I could find a replacement adjustable fuel pressure regulator. I've been searching the internet like crazy and can't find one. I'd think that one exists, I just can't find it. BTW, I have Snow Performance water/methanol injection on mine, it too works great.
It seems to have helped a little. I'll know more once I get it back on the dyno for some fine tuning of the program. Any idea how accurate electric fuel gauges are? The reason I ask is because the tech I spoke with at KB suggested that I check the pressure at the fuel rail just to make sure that my in-cab gauge is giving me accurate readings. I guess what they're getting at is that the electrical gauge is not as accurate as a mechanical gauge. Any ideas? One of the problems I'm having is that I'm not getting the fuel psi at idle that they (KB) say I should be getting. At idle my gauge is steady at 28 psi. According to KB, at idle I should be seeing 32-35 psi. Also, at 0 psi boost I should be seeing 40 psi and under full boost I should be seeing 1 psi per lb of boost, which in my case should be 47 psi. When I am at WOT the most I am seeing is 42-43 psi. Not sure what the problem is, if I even have a problem. I replaced the fuel pressure regulator a few months back and I change the fuel filter every time I change oil (cheap insurance). At this point I don't know what else to check with the exception of the pressure at the fuel rail. My frustration is growing.
I have a Nordskog Digital Gauge. It is reading what KB is saying it should read at idle and WOT. Try calling these guys. Around here, everybody says they are the best. lonestarperformance.com
"I just wish I could find a replacement adjustable fuel pressure regulator. I've been searching the internet like crazy and can't find one. I'd think that one exists, I just can't find it."
OK, just out of curoisity, what is wrong with all the adjustable regulators on the page of the link I posted from the summit catalog? Including the A1000 you were most interested in?
What's wrong with them is that they are not direct replacements for the OEM regulator. I'm probably asking a lot, but I want to be able to remove the OEM regulator and and drop in an adjustable aftermarket one in it's place. At this point I don't think one exists. I'm not even sure how you would install the ones that are on the link you sent. What would you do with the current OEM regulator? The regulator that is in there now is not much bigger than a PCV valve. If I were to try installing a regulator like the ones in the link you sent, what would happen to the OEM regulator? I've contacted Kenne Bell with my dilema to see if they have any suggestions but I haven't heard back from them yet. They only thing they did tell me is that I have a problem but not sure what would be causing my loss of fuel pressure. Overall, I'm off by about 5 psi at idle and 5 psi at WOT. I installed a new OEM fuel pump, fuel filter and regulator and still not seeing 32-35 psi at idle, I'm only seeing 27-28 psi. This problem is really getting me frustrated and pissed off. At this point I don't know what else to do. Thanks for the input though! I open to any suggestions.
