Vin numbers
Old Oct 17, 2002 | 12:29 AM
pklittles's Avatar
pklittles
Post Vin numbers
I recently bought a "69" F-100. But I need to know the actual VIN # decoding to make sure. The # is F10ADB55214. There are other #'s beside it on the original owners card (the original plastic embossed card). Any info will help.
Old Oct 17, 2002 | 08:27 AM
speedking390's Avatar
speedking390
Vin numbers
Hi I did a check on your vin and here is what I came up with
Model Year: 76
Series: F100 - 4x2 Pickup
Engine: 8 Cyl, 460ci (7.5L) 4bbl
hope this helps also did you check the Vin number on the door of this truck.
Steve
1970 f-100 Custom 302 2bbl 4 on the floor, my "economy" machine 1970 F-100 Sport Custom 390 2bbl 3 in the tree with factory overdrive.
1978 F-150 Custom turned into a dune buggy 300-I6 4 speed
Im a typical teen, i just have to change it!
Old Oct 17, 2002 | 07:21 PM
mk's Avatar
mk
Vin numbers
Sorry Steve, but you're way out on that decode. It looks more like a 68 sequence number. I'll have to check my books to be sure or maybe someone else will be quicker with the right info...
Old Oct 17, 2002 | 09:15 PM
dhickey's Avatar
dhickey
Vin numbers
From what you wrote this is what I got
F10=F100
A= 240 I-6 150 Max Gross HP at 4000 RPM, 234 Ft/LBS max gross torque
at 2200RPM, 9.2:1 compression ratio, 4.0x3.18 Bore&Stroke
D=Dallas Assembly Plant
B55214= July 1967.... B54,000 - B67,999
Hope this helps
Old Oct 17, 2002 | 09:55 PM
speedking390
Vin numbers
Sorry guys I just used that vin decoder under the tech articles heading on this site
Sorry agian
Steve
Old Oct 17, 2002 | 10:40 PM
pklittles's Avatar
pklittles
Vin numbers
Thanks Y'all that helps a lot. Now I can start the rebuild a little more acurately. Anybody know where to get a wing window for the drivers side?????
Old Oct 18, 2002 | 07:29 PM
mk's Avatar
mk
Post Vin numbers
Yours sounds like borderline between 67 and 68 production. Does the vent window have a straight bar latch or the upright handle?
Old Oct 19, 2002 | 09:20 AM
pklittles's Avatar
pklittles
Post Vin numbers
It has an 'L' shaped latch on the wing window.
PkLittles
Old Oct 21, 2002 | 02:09 PM
mk's Avatar
mk
Vin numbers
Your truck is a 67. Those vent windows are 67 only as they changed for the 68-72's. I don't know about new ones but you can check the FTE store and classifieds.
Old Oct 21, 2002 | 02:56 PM
1970f2504x4's Avatar
1970f2504x4
Vin numbers
